Never really figured out the point of Le Creuset...
I'd never picked you as the trolling type before.
Because I'm not. Don't throw me into the troll category just because you don't like what I say.
Cry me a river, Howie :laugh:
If you weren't trolling, you'd have substantiated your initial comment.
What does the enamel do?
It's smooth, hard, chemically resistant, extremely durable, can assume brilliant, long-lasting colors, and handles high temps very well, to paraphrase wiki
You add that to all the benefits of solid cast iron cookware, and I can't see what's to dislike.
Smoothness and hardness don't matter for the outside of a cast iron vessel, nor does chemical resistance. The durability of the enamel is certain to be lower than the base iron. Something else will fail before the cast iron is damaged by heat.
I'll give you aesthetics. But it's up to you to decide if the price premium is worth it, and I suppose you did decide.
for a fair assessment, (high) temp handling and durability are a weakness of enameled cast iron compared to plain cast-iron or other vessels. i wouldnt heat enameled too much. also, hardness of enamel surface = prone to chipping/peeling. smoothness is a non-point, unless you compare at the microscopic level or something; practically, any alum/ss surface would serve as well
where enameling has an advantage is when you need a cast-iron vessel (for heat capacity), but want a non-reactive surface. of course, it does look pretty too
