Originally posted by: Chrono
good god. you can buy a damn router for 15-20 bucks at fry's (airlink). it's not the best but it WORKS.
Originally posted by: Sketcher
Have you bridged the modem connection and the LAN NIC in your Network Connections?
You said it WAS working and all of a sudden it isn't.
When your wife's PC quit connecting; was yours still able to access internet?
Any changes at all between the working/non working issue?
not bridged, I need to get comm between my 3 pc's first.
no changes were made.
Originally posted by: BriGy86
citrix was saying he was using dialup anyway, what good would a router do?
FWIW, what good would a switch do for a host and 2 clients to share a dial-up connection?.![]()
I'm legitimately trying to help you out here, did you swap your hub back in yet? Are you going to to see of we can isolate this down to the switch?
he's using a file sharng server also
Post the ipconfig /all of each machine.
Its not a "server" just a old POS HP running 2000 pro with a raid5 that my wife and I use to store stuff. I dont even have a monitor, mouse or keyboard hooked up to it, just power and cat-5
Mine
C:\Documents and Settings\Don>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : darkstar
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter home:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel 8255x-based PCI Ethernet Adapt
er (10/100)
Physical Address. . . . . . . . . : 00-A0-C9-0D-69-FB
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.0.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
PPP adapter BI:
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
IP Address. . . . . . . . . . . . : 172.16.156.80
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 172.16.156.80
DNS Servers . . . . . . . . . . . : 172.16.4.27
172.16.7.235
Primary WINS Server . . . . . . . : 172.16.4.50
Secondary WINS Server . . . . . . : 172.16.4.1
NetBIOS over Tcpip. . . . . . . . : Disabled
Originally posted by: Lifted
Actually, I seem to remember having issues, way back in the day, with NIC's not receiving being able to autodetect on BayNetworks switches, which is a fairly common problem to begin with.
Are you sure the switch is 10/100? Try setting the NIC's to 10baseT and see what you get.
It's either a Layer 1 or Layer 2 issue, so try manual configuration of the NIC's and also try checking the config of the switch for VLAN's or filters.
Originally posted by: spidey07
oh crap.
just realized you are using ICS.
you're done. game over man. there is nothing I can help you with anymore, time to just shoot the ICS box with a large weapon.
How about the ipconfig /all of your wife's machine?
both are 100base-T hubs. both nics are set to 100/full duplex and were before all this started.
