- Sep 28, 2005
- 20,851
- 3,200
- 126
Tami as Xavier stated i dont think you are still quite understanding how MESH Wifi products works.
Normally when you have mesh devices, you need to disable all WIFI except mesh, so you can have zero hand off capability.
By having 2 different devices your causing a overlap.
You need to pull all other wifi AP devices / extenders off your network, and get more google wifi devices to fill in gaps like Xavier stated in his first post.
This is why a lot of us that know network dont like mesh too much.
Its not open flexibility unless you stay within the cardboard box mesh is.
The main point of Mesh devices (your Luma's) is for seemless handoff between AP's so that your client devices are connected to the best AP at all times. However, you have non-mesh devices in the mix. Using the same SSID prevents you from manually switching networks, but you lose the intelligent handoff. Meaning even though you were standing next to the R7000, your client device may still have been connected to one of the Luma's as the signal from them isn't low enough to drop the connection. Adding extenders can actually make matters worse because you could be causing signal overlap. The ideal setup would be to lose the extenders and turn off the WiFi on the R7000 then get more Luma's to fill any gaps.
