Duvie thanks for the tips!
The ram is in the 1 & 2 slots and I applied artic silver 5 to the chipset. I'm sitting right now at 9x300 for a 2.7ghz speed atm. And I'm about to run prime95 to see if it can go even higher. I also downed the voltage to 1.56V to see if it would work, if it works here then I probably can go even farther if I up that voltage a little more. I'm guessing the ram is what did it. But that artic silver 5 certainly didn't hurt
Finally! 280+FSB!!
I typed in my values into that ram script, and said that 166 would work out great, except I cannot get the board to boot using 166mhz and going 2.5-4-4-8 (tried 2.5-5-5-8). This is using that 9x300 for 2.7
Finally! 280+FSB!!
