Need to measure some cylindrical storage tanks for their diameter
34,484
Buy a gallon of paint and a 1 ft wide roller
Paint stripe around tank
Measure how many sq feet the gallon is supposed to cover
Measure how much paint is left
Use math to determine how much paint you used
Do math and figure how long the stripe is
Divide by pi
Rubycon
Madame President
Aug 10, 2005
17,768
485
There's a lot of calories in three pies!
Also if the OP is working indoors you can add some fog to the space and use even a 5mw cheap laser pointer. ;)
Rubycon
Madame President
Aug 10, 2005
17,768
485
Divide by pi
Haha speaking of rolling they do make rolling measures. ;)
34,484
Place bird seed on top of tank at one edge
Release swallow at opposite edge
Measure time it takes swallow to fly from one edge to other
Use math to determine distance
34,484
Are you moving the tanks yourself or hiring a contractor? If contracting, make them figure it out.
34,484
Sell tanks on eBay, listing them as 16' tanks.
Deliver to buyer
Check feeback, buyer will give you exact dimensions.
Give refund and get tanks back.
