Need to measure some cylindrical storage tanks for their diameter
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
Go to a hardware store. Get a couple of pieces of 1/2" CPVC and a union (to make it long enough). Get a couple 3/4" CPVC T's. They'll slide over the 1/2", but will be a little tight. Make a giant caliper this way. Hold one end on the edge of the tank. Slide it across the tank - the widest point of the tank (diameter) will push the other tee out the farthest. Climb down, measure. No math involved (since you can't do it the simple way of measuring the circumference.)
Howard
47,982
11
Doctor, you are a miracle worker.
Squisher
21,204
66
How accurate do you have to be? Plus or minus an inch? Plus or minus a foot?
The reason I asked this is if you only have to get the dimension within a foot you could probably could make a number of big radius gauges. You might be able to be even more accurate than I think.
They sell an Arc Master Radius Gauge ($120)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=120374788669
edro
24,326
68
Wrap a rope around the tank.
Tape it as you go, keep it taught.
Divide length of rope by 3.141.
her209
56,336
11
Step 1: Wait until sun comes out.
Step 2 Measure width of the shadow cast.
FUCKING WIN!!!
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
We need a MacGyver smiley
34,526
Two measuring tapes and two 2x4s or other long straight things (pipe, rod, etc) of equal length both longer than diameter of tank.
Lay the rods on opposite sides of the tank such that each rod touches the tank wall. Run a measuring tape from the end of one rod to the end of the other. Repeat with second tape on other ends of rods. You will have sort of formed a rectangle. Adjust the angles of the rods with respect to each other until the two tapes show the same distance, making sure the angle between the tapes and rods are 90 degrees. The measurement given on the tapes is the diameter.
ussfletcher
2,569
You know.. you could just estimate.. make a line on the floor with chalk about even with both sides and measure across.. D:
Howard
47,982
11
Hmm... two spirit levels could get me pretty damn close.
EDIT: Or plumb bobs. Can I do it with three, so that it doesn't matter if I've got diametrically opposed points or not? Is it possible to calculate the diameter of a circle given a triangle whose points all lie on the circle?
DrPizza
Mar 5, 2001
49,601
167
111
Yes. The point where the perpendicular bisectors of the sides of the triangles meet is the center of the circle. (Circumcenter.)
Howard
47,982
11
I think they teach you this stuff in high school so you can forget it later... thanks!
