Need to measure some cylindrical storage tanks for their diameter
Howard
47,982
11
What's the easiest way to do this? Most of them are between 8 and 14 feet in diameter.
MotF Bane
60,801
10
Duct tape and a piece of string. Tape one end of the string to the tank, walk around the tank, wrap a bit of tape as a marker to the loose end to indicate where the tape begins to overlap. Measure this length of string.
BoomerD
66,430
14,836
Pecan pie ALWAYS gives the wrong answer. Only apple pie is accurate enough for measurements.
Everyone knows this.
Use a 100 foot tape measure...divide by 3.14...get answer that's close enough for government work.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
As said... easiest way is use string to get circumference and then use math magic to make it go *poof*
THE CIRCUMFERENCE IS NOW DIAMOND... er... DIAMETER
JTsyo
12,043
1,136
Lay a ruler next to it, get above the cylinders and take a picture, then use the ruler as the scale.
Howard
47,982
11
barrel distortion
I was hoping that you guys could come up with something other than walking around with a string. The tanks are damn dirty and I can't get access to the full circumference for many of these tanks.
Daedalus685
1,386
Stand x meters away from the tank (distant to closest point of the tank, not its centre as if you could measure that well... you know), measure the angle (theta) subtended by the edges of the tank.
Provided x is large enough (at least double the radius to get a close value):
D=2xtan(theta)/(1-tan(theta))
ussfletcher
2,569
Well, you could measure your distance away from the tank and take an angular separation measurement of both edges...
Edit: I lose.
Analog
12,755
Fill them full of water - take note of how many gallons. Once you've figured out the volume of water, a quick calculation will give you the diameter of the tank.
rcpratt
10,433
110
Clearly this is simpler than a string and circumference.
Analog
12,755
actually, I was thinking that the cylinder could be accelerated to near the speed of light, and its mass variation coupled with time dilation would yield a relativistic approach to this problem, but alas, I couldn't find the right approach. Perhaps there is something in QED..
highland145
43,973
6,338
barrel distortion
No access to the top?
Gibson486
18,378
barrel distortion
find as builts?
