Need to dismantle large satellite dish.
Feb 4, 2009
35,862
17,406
It probably just regular metal but I agree with the above it’s probably worth something to someone just not sure if you want to deal with that.
Also I am shocked nobody posted this
Reactions: thestrangebrew1
Midwayman
5,723
325
It appears C band is still a thing... and they pick up some dishes posted on Facebook and Craigslist.
but I’m not seeing a quick list of unscrambled channels
Usually you can pickup major broadcast networks in multiple locations. Its especially good for international channels that no cable carriers carry.
Reactions: NoTine42
thestrangebrew1
4,116
799
Here's a better picture of it. Don't mind the mess, kids were swimming last night. My plan is to take the dish down, rip that bush out and build an outdoor kitchen in that area, since I have water and gas behind that broken fence on the side of the house. It'll be a multi-year job for sure lol.
NoTine42
1,387
78
Yep, that’s a BUD (big ugly dish). Probably a good amount of concrete holding that steady
In addition to a ground rod? I would think there should be a pair of coax wires in there, but I’m not sure what that gets you so close to the house. (Could be used for MOcA Ethernet extender if it was farther from the home)
thestrangebrew1
4,116
799
Any wiring that was hooked up to it was probably re-routed to the smaller dish at one time I'm thinking. I don't see any wiring to it anymore. It's big and ugly for sure. Been a long time coming, but I'd at least like to get it down and get the bush ripped out so I can start planning for the kitchen.
[DHT]Osiris
17,456
16,777
Oh you should contact that smiley cooking guy, he'd use it as a giant colander for a pasta bake for 200 or something.
bbhaag
7,483
3,104
Hope you have some buddies that can come over and help you out because that looks likes it's going to be a beast to get down off that pole. Either that or like someone else mentioned attach some ropes to it and have a couple people pulling it away from the house as your're cutting the base of the pole with a saw.
lxskllr
60,573
10,934
If there's a decent anchor in the fall direction, it would be pretty easy for one person to take down. Attach a rope up high, and setup a Zdrag from the anchor point. Cut 2/3± through the back, then haul it over with the rope.
Feb 4, 2009
35,862
17,406
Yeah that has to go.
Not sure what your plan for the space is but if you need a simple cheap fix. Cut it down, scrap it. Then get a planter big enough to cover the base and cut a small hole in the planter where the leftover pole from the cut it.
Spacehead
13,067
9,858
That thing has more holes than a german shower head, I don't think it would work, but now I kinda want to try it with one of those solid ones that don't have the holes. I think it would be fun tbh.
Situations like this is why someone invented Flex-Seal. Cockadoodle-dooo!!!
snoopy7548
8,289
5,366
Seems like a very fine-mesh so it might not be enough to break the water's surface tension.
Hans Gruber
2,535
1,364
I remember those old dishes. There were some neighbors in the area that had those and the ham radio setups that were so big they should have been illegal. Now about that water slide from the 70's.
