Jimzz
- Oct 23, 2012
- 4,399
- 190
- 106
For those of us who haven't seen hundreds of brake pads, care to explain what we're looking for and what the differences are in the MSDS sheets?
Care to explain why Advance Gold pads are fine for every day driving unless we're towing or racing?
The MSDS has what is in the brake pad (ingredients). You dont use the MSDS to see what pads are better, at least not easily, but to see who makes what. Advance does not even have MSDS sheets on their brake pads, they just repost the federal-mogual pads MSDS as they are the same pad.
As far as pads when I was a mechanic I talked with my customer to see their driving habits and choose a pad based on that. If they were older or said they liked a pad that grabbed quick and hard I usually use a cheaper pad as the lower end ones are EE rated and grab at lower temps. If you tow or drive hard I went with performance friction for a while (auto zone use to carry these) or another FF rated metallic pad. For most cars today ceramic works fine.
The reason I recommend advance gold pads for most street driven cars is they are typed to each car. If your car came with ceramic then you will get the same type pad and so forth. I have not seen this to be wrong but I am sure there may be a case where this does not line up but I never saw it. This takes out the guess work or telling someone to flip the pad over and look at the material and then go in some long explanation. The gold pads at advance, as you can see through their copy F-M MSDS sheets, are good Wagner pads. So you get a good name brand pad and dont have to guess or think to hard about it. This works well for those that are not in the auto field.
