Brembo drilled rotors. I used Stillen pads/rotors in the past. was pleased.
Napa Premium or OEM only.
All of the advance/autozone/pep boys brakes are total junk, in my experience.
....And your life depends on your brakes and tires. "Not racing or towing" is a ridiculous argument when 10ft of stopping distance can mean saving your life. When you're in a wheelchair for the rest of your life you'll wish you had coughed up the extra $40 on quality parts.
Cheap out on oil, spark plugs, wax, other crap that is just money... But brakes and rotors need to be quality parts.
Anything to back it up or just more junk internet ads and forum BS you are spieling?
Ive worked on more cars in 1 year then you have in your life and I have used pads from napa, az, advance, dealers, etc Do you even know who makes Advance gold pads right now? I do.
I know I've never seen more comebacks for brake noise than when using those wearevers, gold or not. Even thermoquiets have less comebacks. I didn't mind the extra 1.5 to warranty them out over and over until someone gave and ordered Akebonos but it tended to piss the customers off.
Napa Premium or OEM only@#@#
All of the advance/autozone/pep boys brakes are total junk, in my experience@#@#
@#@#@#@#@#@#@#@#And your life depends on your brakes and tires@#@# "Not racing or towing" is a ridiculous argument when 10ft of stopping distance can mean saving your life@#@# When you're in a wheelchair for the rest of your life you'll wish you had coughed up the extra $40 on quality parts@#@#
Cheap out on oil, spark plugs, wax, other crap that is just money@#@#@#@#@#@# But brakes and rotors need to be quality parts@#@#
I actually agree with you on the Chinese rotors. If anything, they're better for the majority of the pad-chewing, rotor-warping drivers out there.
But OEM pads can squeal just fine, and aftermarkets can be dead quiet. Brake jobs, like most other things that end with 'job,' are much better with lube.
Caliper pins need to be lubed and free. Pads need some lube on them- if not the grease, the tacky spray stuck works. On the back (obviously) and also lightly around the corners where they touch the pad slides. Plus all hardware (slides, shims, and-rattle clips) present and in good shape.
If all that's done, and you're not using $20 pot metal Autozone pads, they're not going to squeak/squeal. Factory pads are good, but the amount of markup on them is absurd. I don't recommend anyone pay $100 for a set of stock brake pads for their Honda.
The biggest deal is to stick with the same pad material they came with. If your Accord has semi-metallic from the factory, don't use ceramic or you'll trash your rotors and you'll hear squeaking and squealing before your pads wear half way through.
I'm thinking maybe the Akebono pads for $52**95 and a pair of Brembo rotors for $50**95 each** Would this work or can I not cross manufacturers in rotors and pads?
Thanks
I had an opposite experience - the semi-metallic pads will eat the rotors in a matter of a year on my wife's Mazda MPV (nose heavy car). I switched to ceramic pads and I haven't had to deal with her brakes in 2 years now (the same number of miles driven). There is also no noise.
The ceramic pads are on my 2004 Accord. No noise, decent stopping performance, the pads/rotors last longer.
Centric rotors and Porterfield R4S pads. Epic winning combination.
