Need middle school math help
wnied
4,206
24 + 8 / 2 X 6 - 4
musing pemdas, how can I make this equal 6?
I r math stupid
wnied
Ken g6
Moderator
Dec 11, 1999
16,836
4,816
75
If 24 is outside the division, it's too large: 24-4 = 20, and something's added to that.
If 24 is part of the division, you have (24+8)/y = 32/y.
if 32/y = 6, then y = 32/6 = 5.333... You can't get that from integers without another division.
I think the normal answer is 44.
ch33zw1z
39,838
20,433
yea, without parenthesis I got 44
dullard
26,201
4,871
24 + 8 = 32 / 2 = 16 x 6 = 96 - 4 = 92
Please tell me this is a joke.
First, that is completely missing the point of order of operations. Second, most of your equalities are not equal. For example, look at your first equality. 24 + 8 is NOT equal to 32 / 2. Never has been, never will be.
According to correct order of operations, you add parentheses like this:
(24) + ((8 / 2) X 6) + (- 4)
Now do the work inside parenthesis before doing anything else. There is no situation in the given math where 24 is added to 8.
dullard
26,201
4,871
Also, if the OP's math problem was written correctly, this would never be a confusion to anyone who can do math. Why leave it up to possible incorrect interpretations? Just write it like this and almost everyone will do it right: (24) + ((8 / 2) X 6) + (- 4)
snoopy7548
8,305
5,385
I got 116.
24 + 8 / 2 X 6 - 4
Using PEMDAS (remember, multiplication and division are done left-right, whichever comes first)
24 + ((8/2) * 6) - 4
24 + 96 - 4 = 116
EDIT: Nevermind, I got 44. 8/2 = 4, not 16. Me so dumb.
serpretetsky
642
26
101
What is the original prompt? This current post isn't clear since it doesn't equal 6. Can you move the numbers around? Can you put parenthesis anywhere you want?
purbeast0
53,764
6,645
I got 116.
24 + 8 / 2 X 6 - 4
24 + 96 - 4 = 116
You also added in an extra set of parens that is not needed.
24 + ( 8 / 2 * 6) - 4
Just one set is all that is needed.
pete6032
8,421
3,817
I think the prompt is asking the user to write in parenthesis into the equation such that the final answer would be 6?
Reactions: ch33zw1z
ch33zw1z
39,838
20,433
Closest I came is 4 by adding my own. Funny, I was kinda thinking the same thing, as adding your own parentheses is a great way to reinforce PEMDAS
24 + 8 / 2 X 6 - 4
(24 + 8) / (2 x 6 - 4)
(32) / (12 - 4)
(32) / (8)
4
pete6032
8,421
3,817
24 + 8 / 2 X 6 - 4
(32) / (12 - 4)
(32) / (8)
4
Yes I wonder if OP made a typo or the math book made a typo.
Reactions: ch33zw1z
dank69
37,630
33,366
24+8 is 32. But that isn't what you typed. You typed:
There is a very subtle but important difference there.
He was clearly piping his results. Not saying it is okay, but that is what he was doing.
dullard
26,201
4,871
Yes. But it both got him the wrong result and spreads the idea that math works that way. It doesn't. Just skip the shortcuts that are factually incorrect. They are not the way to success.
H T C
615
459
24 + 8 / 2 X 6 - 4
You can't because the end result is 44.
The order of the operations is as follows: Unless with a parentheses, no + or - operation is conducted BEFORE an * or : operation.
24 + 8 : 2 * 6 - 4 =
24 + 4 * 6 - 4 =
24 + 24 - 4 =
48 - 4 =
44
Those that said 44 was the answer are correct.
dullard
26,201
4,871
I think I figured it out. Just by ignoring a few rules of math, you can get 6.
I'll multiply everything by 1. That won't affect anything. Since most numbers divided by themselves is equal to 1, we can use y / y = 1.
  • (24 + 8 / 2 * 6 - 4) * y / y
Now, split out that multiplication:
  • (24 * y + 8 * y / 2 * 6 - 4 * y) / y
Lets just choose any completely randomly chosen number. Nothing complicated though. Lets choose, lets say, for no particular reason, that maybe y = 0. Clearly 24 * 0 = 0. Also 4 * 0 = 0. So now we get:
  • (24 * 0 + 8 * y / 2 * 6 - 4 * 0) / y
  • (8 * y / 2 * 6) / y
Well we also know that 8 * y / 2 = 0 = y , so now it becomes
  • (y * 6) / y
Just cancel out the y values and, it is simple
  • 6 * (y / y)
  • 6 * 1
  • 6
Just ignore that one underlined word above.
