Ryan97
Hi guys, it's my first post and a bit of a nooby question. But at the moment I use a basic switch which plugs in to my router then allows me extra ports to connect to my network. My question is, do large mounted switches work this way? As in proper network switches? Do they simply plug into a router (obviously they need power) or how do they work? How would I go about setting one up?
XavierMace
4,307
450
They can, if you're just wanting to use them as a dumb switch. Setup depends on brand and network.
ch33zw1z
39,838
20,433
Topic of managed versus unmanaged switches, that's so you can google it :p
like XM said, depends on what type of switch you have.
EdHerVA
19
Ryan, I use an Unmanaged 8-Port TP-Link Gigabit Desktop Switch. It is plug and play and works perfectly: 19.99 on Amazon today. I have Verizon FIOS- 150MGb down and up
sdifox
101,224
18,231
So if you are just looking to add more ports sure. Know youbare just saving five bux.
Personally I prefer network equipment with metal shell, better heat dissipation.
Genx87
41,091
513
Most managed switches if you factory reset them will come up with the default VLAN for every port. Then it acts like a dummy switch for all intents and purposes.
VirtualLarry
56,587
10,227
Generally, I do too - except - in the case of putting the switch directly under a WiFi router. The metal shell causes the RF from the Wifi router to reflect back into / onto it, and it tends to heat up routers something fierce, burning them out prematurely.
sdifox
101,224
18,231
Why would you put the switch under a wap or router?
ch33zw1z
39,838
20,433
meh, its a switch, shove that thing behind the cabinet like a standard user
sdifox
101,224
18,231
You've never heard of "stackable" networking equipment? Maybe there isn't enough shelf space to spread the devices out flat?
We talking home equipment here aren't we?
Besides, rackmount stuff have active cooling. My Baystack 5520-48-PWR has like six 40mm fans on its side.
Rifter
751
I just have all my network gear mounted to the wall behind my tv, most routers and switches are wall mountable.
sdifox
101,224
18,231
router:
https://www.newegg.com/Product/Prod...1041&cm_re=linksys-_-9SIA7JJ5MR1041-_-Product
switch:
https://www.newegg.com/Product/Product.aspx?Item=9SIADYN5T64310
Technically, those aren't matched, the bottom switch stacks with the original WRT54G(L), the top router is a newer model, but there is a stackable switch that goes with it too.
Lukz that is not what I was thinking of when you said stackable.
Ezra. W
13
Yeah, the switch in your pic is a chassis based switch I suppose? Stackable switch generally has a dedicated stacking port on the backplane for stacking, and it uses a stacking cable that comes with the switch to connect two stacking ports. So you can operate those stacking switches as an single entity. BTW, stackable switch is more cost friendly than this higher-end chassis switch.
sdifox
101,224
18,231
Chasis is just consolidated stacking.
