Need help translating a Japanese help screen
vulcanman
614
I am trying to use a one of a kind video conversion tool thats written in japanese. I would like help from anyone here who knows Japanese.
Image Link Here
Thank you in advance !!
amdhunter
23,276
165
Image Link Here
It says: "OMG ISTS GODZIRRAAAAAA!!!"
Ariannaid
You're missing the katakana symbols, for some reason (which is why there are all the question marks mixed in), but here's my best guess at it:
Translated Dialog
Note that the "Available Segment" would be used if you want to convert only a certain portion of the input file; it's a bit awkward phrasing on my part, I know.
effowe
6,021
18
I suggest finding a different tool that does the same thing but is written in english, google yielded many results for vro to vob.
vulcanman
614
Ariannaid ... thank you !! It helps a lot. BTW, there is no other tool out there that will take a VRO file and make a series of VOB files in one shot. All the rest (incl. TMPGEnc) takes a very long time to convert and makes your PC useless for anything else during the conversion. This tool works great !
ASK THE COMMUNITY
