monkeydelmagico
Hyper 212 or whatever 120mm floats your boat. I find matching fan sizes more aural pleasant than various sizes. It will look "crazy huge" compared to stock though.
For now yes.
Edit: Okay, I unplugged both front fans and the rear and it almost sounds exactly as it did before, including the higher-pitched sound, so that leads me to believe most of what I'm hearing is the stock Intel cooler fan. I've only ever used stock coolers since I don't OC. I'm open to another one, but not something crazy huge and it must be quieter than what I have now. Any immediate suggestions come to mind?
The difference you're seeing is the system RAM that is being used by the IGP for its VRAM.
You can test for sure by just stopping the CPU fan with a pencil or whatever. The system isn't going to overheat or anything from the fan being stopped for a minute or so. Hell, I run an i3 2100 with the fan on the stock cooler unplugged without issue.
Unplug the CPU fan to make sure. In my experience, stock Intel fans these days are not that noisy. Leave the case open and inspect it while it is on with all fans off and see if you still hear it.
If you're hearing a high pitched whine, it could also be your PSU.
My PSU is a Silencer 610 from spring 2008. I thought it only had the one 80mm rear fan, I wonder why it's so loud.
The Seasonic looks good. I was looking at SPCR's recommended PSU list - interested in the fanless Seasonic X-400, but I don't know if 400W is enough if I plan to get a Radeon 7850 or 7870. The X-650 (and more recently I suppose, the X-560/660 etc.) seem the best as they are higher output than the X-400 but can still run their fans in a very quiet mode or not at all below 20% load. However, the X-560 is more than twice the price of the S12II.
For the coil whine, are you talking about chips in the PSU, or could this be any chip such as on the motherboard? I don't recall hearing this sound with my old system with this same PSU, but maybe I just wasn't listening for it or the fans were louder.
"Silencer" was a misnomer created by PCP&C who insisted on using 80mm fans, and who also created the myths of single +12v rail being better and modular cabling being bad.
I had a Silencer 610. It was about as quiet as my Antec TP Quattro 850. Which is to say, not very. I do understand many feel that those two PSUs are rather quiet, but they're probably coming from using high RPM CPU and GPU fans and probably couldn't hear the PSUs over those. I was (at the time) trying to build a quiet rig.
Exactly. The Seasonic X series are very good, but are also way off the deep end of the price-performance curve.
Any chip, hopefully it is in an exposed place where you don't have to void any warranty stickers to test it.
Interesting...so, modular is generally good as well? I remember hearing some people not liking them but I can't remember why...maybe extra stiffness in the cables or extra length in the PSU to handle the rear ports...I don't remember.
Yeah, I will have to do more reading about the exact volumes I can expect from the S12II vs. other offerings. I like the idea of zero noise at low load, but I'm assuming the S12II would still be an improvement in volume over what I have now. But is it a large enough improvement to justify buying a new PSU is the question.
Regarding the coil whine, what type of components could cause it - a chip, capacitor, an actual coil? From searching it seems people tend to complain about this the most with video cards and power supplies.
Regarding the coil whine, what type of components could cause it - a chip, capacitor, an actual coil? From searching it seems people tend to complain about this the most with video cards and power supplies. I'm not sure I would be comfortable with the fingernail polish thing. I'll see if I still hear it after getting a new PSU, which I probably won't do until I get the video card.
Speaking of getting the correct wattage PSU so you don't have a lot of unused cables, what is probably the sweet spot (not too much, not too little) for a system like this? i5 no OC, 16 GB RAM, one SSD/one HDD, no optical drive, three case fans, and eventually a Radeon 7850 or 7870 (I know we don't know exact power figures for these yet). Maybe around 520W like what mfenn suggested?
