Thanks mfenn. Sorry to keep this going but one last question I am trying to figure out regarding the Precision PS07 vs. the Temjin TJ08-E. I'm concerned that the large front opening on the Temjin will make it be a little loud, even if I replace the stock 180mm fan with a quieter 140mm. This makes the Precision a little more appealing since it's closed off in the front and comes with 2 120mm fans. However, this PC is going to be on a shelf below and in front of me, with the front of the case facing to the right and the left side facing towards me. The Precision has a large side vent, and maybe this will make it just as loud since it's facing me. Also, I have read that you can reduce the noise of any of these fans by controlling their voltage. I don't intend to use a fan controller, and I'm not sure how much I'll be able to control them if I plug them into the motherboard.
So, my options:
1) Get the Temjin and undervolt the 180mm fan or replace it with a quiet 140mm.
2) Get the Precision and use the stock fans, maybe undervolt them.
3) Get the Precision and replace the front fans with
these (10.7 dbA).
4) Get the Precision and remove one of the front fans since I'm not sure both are necessary. Do I really need to direct air towards the video card when it will have a massive plastic covering over the whole thing anyway?
Just trying to sort out which option will give me the least noise and still cool well.
Thanks.
