My Z680 subwoofer blew while watching Transformers
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Originally posted by: sdifox
What size is that woofer? The Logitech one. Looks like a 6.5 at most and I got 4 6.5 on each of my main.
Me think his amp clipped and that did the woofer in.
P.S. What are you doing with so many different subs??? And the second picture, maybe the speaker cable should not be blocking the drivers? Or do those just serve as speaker stand?
That's the z-560 sub with an 8" woofer, very similar to the sub that came with the z-680 set in question.
This was a picture when I was selling my SVS PB10 after I got my SVS 20-39 PC+ and I put the Logitech subwoofer and speakers into my setup just for comparison purposes for threads where people would complain about the size of the Logitech speakers, etc.
Now my subs are a pair of SVS cylinders.
The Logitech speaker was just placed on top of the real speaker, not used in that position except for the couple of tests that I did with it in that position.
sdifox
100,505
17,957
Generally speaking, those small systems cannot be pushed safely. They are cheap enough that the safeguards are just cut out to save money. Not necessarily a bad trade-off, you just have to be conscious about it and not crank it past its limits.
Oh I know, just kidding about that before ;)
<a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wi............vs_SVS.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc..........Log_vs_SVS.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu......dom/Log_vs_SVS.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/sp.../Random/Log_vs_SVS.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/spmclaughlin/web/Random/Log_vs_SVS.JPG">https://mywebspace.wi............PG</a></a></a></a></a>
<a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wi............20Rock.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc..........0vs%20Rock.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu......og%20vs%20Rock.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/sp...om/Log%20vs%20Rock.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/spmclaughlin/web/Random/Log%20vs%20Rock.JPG">https://mywebspace.wi............PG</a></a></a></a></a>
ok. So now you have 2 water heaters... ever puke :) ?
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
<a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wi............VS.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wi............vs_SVS.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc..........Log_vs_SVS.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu......dom/Log_vs_SVS.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/sp.../Random/Log_vs_SVS.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/spmclaughlin/web/Random/Log_vs_SVS.JPG">https://mywebspace.wi............a></a></a></a></a></a>
<a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wi............ck.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wi............20Rock.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc..........0vs%20Rock.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu......og%20vs%20Rock.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/sp...om/Log%20vs%20Rock.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/spmclaughlin/web/Random/Log%20vs%20Rock.JPG">https://mywebspace.wi............a></a></a></a></a></a>
Not yet?
sdifox
100,505
17,957
<a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wi............PG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wi............VS.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wi............vs_SVS.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc..........Log_vs_SVS.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu......dom/Log_vs_SVS.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/sp.../Random/Log_vs_SVS.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/sp.../Random/Log_vs_SVS.JPG">https://mywebspace.wi............t;</a></a>
<a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wi............PG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wi............ck.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wi............20Rock.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc..........0vs%20Rock.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu......og%20vs%20Rock.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/sp...om/Log%20vs%20Rock.JPG"><a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/sp...om/Log%20vs%20Rock.JPG">https://mywebspace.wi............t;</a></a>
Not yet?
Throw in the Telarc 1812 SACD or DVD-A and play it at reference level. I had my ears covered with my hands and I was starting to get sick when the cannons hit.
Oyeve
22,071
885
I would try to replace the driver first. Maybe something a little beefier. Dont know what the ohm on that sub is but if its a standard size with standard mounts changing the driver should be easy.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Well I don't have a SACD or DVD-A player. I'm mainly a movie guy vs. music :p
sdifox
100,505
17,957
Fair enough, I am big on both.
SlickSnake
5,235
Originally posted by: Kaido
Onkyo 605 refurb now $299:
http://www.avsforum.com/avs-vb....php?t=854964&page=130
Dang, that's cheap. I just never liked the Onkyo amp sound.
I had a chance to compare Onkyo when I bought my Infinity Interlude speakers at C.C., and I just didn't like the tinny sound they caused the Interludes to sound like, even the top end Onkyo model at that time. The H/K on the other hand, drove the Interludes effortlessly, and the sound from the speakers was superb using it.
I'm using the 120 watt x7 all digital amp H/K DPR 2005. And there simply isn't anything I have seen or heard lately that can compare with it. It does not have HDMI though. But it is very slim profile, and fits in my entertainment center, too.
