HomeBrewerDude
- Jan 18, 2001
- 14,465
- 1
- 0
Originally posted by: phreakah
don't mean to hijack, but is there anything i can do if my shower is too cold even on the hottest setting? the water heater is turned up all the way and the water is only hot for like 3 minutes then it gets ice cold... sucks!
there is a gasket inside the faucet that has probably worn out causing the hot water to flow regardless of the position of the controller. you can buy a new part at HD for about 10 and fix it in about 45 minutes.
a bad gasket can also cause abnormally cold water flow.
