Hello guys!
i just got a small pretty cool Network Video Recorder, cameras over network, less cabling better quality, i am happy with it, but id like to take advantage of the remote monitoring functions too.
The system has a LAN jack for the internet connection in the rear and in my house, the internet is provided by a wireless modem. the only port it has is a micro usb.
other than getting an additional service from my ISP only for that
, what can i do?
i have too little knowledge on networking, i did a small network with a laptop and a wireless router in order to use the app in my phone to adjust the camera position, i mean, i did use the remote monitoring fuction but it only works if my phone and the system are in the same network. What i did is, i use another laptop i have around there i enabled the internet sharing so i connect the laptop to internet via wifi and the NVR to the laptop via LAN cable, the system did recognize the internet,, and my app too but when i wanted to view the cameras, no video at all, then i decide to try to then (with the laptop connected to the wify, to connect the laptop to the router IN line, and to connect the NVR to the router, and then i created a second wifi network with that router and then it work, but only work if both the NVR and the cellphone are in the same network.
but id like to do this without having a router and a computer all time and without the need of be in the same network in order to work.
i understand a router is for providing internet over wifi or lan, but is there a possibility to use the router (which has both lan and wifi function) to "catch" internet over wifi then to provide internet over LAN to the NVR?
or, then, the laptop does provide internet over lan but then it does not work inthe app.
what can i do?
thank you guys
what can i do?
thank you guys
