Sentential
- Feb 28, 2005
- 677
- 0
- 0
Do you know what revision your prescott is? If its a C0 that would be the main cause. N0, E0 and D0 Prescotts really arent that bad.
I dont know about that because I get the same readings in my bios...I would NOT trust Corecenter at all. Totally BS readings . With a friend of mine, when you restart, corecenter jumps by 7 degrees (C) up
Originally posted by: AnnoyedGrunt
OK, once again, the CPU temperature does not reflect the amount of Energy (HEAT) it generates!
Energy (HEAT) and Temperature are NOT THE SAME.
A good heatsink will keep the processor cool, but in order to do so, it is dumping the heat into the surrounding air at the same rate a small heatsink will.
If your processor is using 100W, you will be heating your room with 100W, no matter how big or small your heatsink. If your processor uses 75W, you'll heat your room with 75W, no matter how big the heatsink.
Also, a bigger heatsink does not heat the room faster, because you are still heating with the same amount of energy. All the heatsink does is change the temperature of the CPU. You are always dissipating the same amount of energy.
For conductive heat transfer, the amount of heat is expressed by:
q=-k(T1-T2)
(T1 = temp 1)
(T2 = temp 2)
(q = heat)
(k = thermal conductivity of heatsink)
So, your CPU heat is always q, and your CPU temp will be determined by the conductivity of your heatsink (k). No matter what though, you are always dissipating the same amount of heat.
Now, one other thing to consider is your monitor. If you have a large CRT, it is probably contributing a significant amount of energy to the room as well. If you have an LCD, then the cpu/gpu are the places to look.
-D'oh!
i'm not sure who this post is in response to, but i stand by my claim that a better heatsink will dissipate more heat into the room than a poor heatsink, especially in context of the OP which i didn't feel the need to repeat.
the OP has claimed that at non OC'd speeds he is stable but when he starts to OC his system goes unstable due to heat. having a better heatsink will allow him to maintain higher OC'd speeds, hence more heat will be sent into his room.
therefore, altho a better hs will enable him to run his PC oc'd it still doesn't resolve his problem of too much heat in his room.
amd 64 chips do run SIGNIFICANTLY cooler.
