Originally posted by: swtethan
if you continue to wait for better stuff, you'll be waiting forever. stuff comes out all the time.
Originally posted by: JPB
Originally posted by: PhoenixOrion
Oblivion indoor and outdoor with CPU running at 2.6ghz then OC card to 10% core and mem.
I can run the video at 10% over. But I highly doubt my cpu will go that far due to memory restrictions.
Run your memory with a divider. I think your mobo supports using dividers, though I've never used an AMD chipset. Keep your multi at 11x, change FSB to 236, and run your ram at 166mhz (a 5/6 divider), which, when overclocked, will only be 187mhz... which is actually UNDERclocked. This will try you for 2.6ghz and RAM won't limit you one bit.
Your resolution is just slightly less stressful than 1280x1024, and that resolution is one that often begins to show some considerable gains with faster processors (depending on the game). But I agree with lavaheadache... hold off on the flatform upgrade until you truly feel you *need* it. That might be at the time Crysis comes out.
Thanks, Ive looked in the bios alot. I dont see where it is to change the fsb and the divider....can ya help me out a little further ?
Ok, I tried the settings you suggested. And upon each boot, it said overclocking failed. So I set the fsb to 220 and it overclocked to 2.4 fine from 2.2......
Originally posted by: Extelleron
That 3D Mark score is pretty low, even for a single-core A64 system. With my Opteron 144 @ 2.4GHz, 2GB of RAM, and a stock 8800GTS I got a score of 6209 on Windows XP.
http://service.futuremark.com/compare?3dm06=1313064
Yes, it does seem low. However, you are overclocked from 1.8 to 2.4 on your cpu. I cannot really overclock my cpu due to memory restrictions.
If you take a look at my score in 3DMark06 from stock to overclock, the cpu score did not even raise one point. I know it really sucks. I need better memory because I know I can overclock this cpu...its being cooled with a Thermalright XP-90.
which games?
The games is in the list in my OP. I made it to 2.6 squirrel. Thanks for the advice. 8)
EDIT : The frames cap is in Quake 4 and Doom 3. Im not sure about Prey or Oblivion.
No problem. Glad I could help. As for Q4 and D3, those should both use the "com_fixedtic -1" without the quotes to remove the 60fps cap (just bring up the console and type that in). Well, I think it works on D3, but on Q4 and Prey it may not work. Not sure.
There is no cap in Oblivion that I have seen. If you're in a position to be getting over 60fps constantly, you need to crank up some AA, download some texture packs and mods, and spend more time outside in the forests. I'd kill to get even a MAX of 60fps in Oblivion at my settings.
