50cent1228
Originally posted by: Special K
Unfortunately, merely not eating unhealthy foods is not likely to get you a six pack. For maximal results, you need to take a more methodical approach.
Losing fat is ultimately a matter of burning slightly more calories than you consume over an extended period of time.
What you need to do is start tracking exactly what you eat each day. Fitday makes it easy. You will also need a starting point for your BMR - this is the number of calories you would need to eat in a day to exactly maintain your current weight. You can find an estimate here - make sure to click on the link labeled "Daily Calorie Needs" to find an estimate based on activity level.
Now, eat that number of calories each day for a week, and track your weight first thing each morning. If at the end of the week, you have not lost a pound, then cut 300 calories from your daily total and eat that amount for each day of the next week. Continue to track your weight, and keep making reductions until you are losing about 1 lb./week. I recommend getting 1.5 gm of protein/lb of bodyweight, 0.5 gm of healthy fats/lb bodyweight, and the rest carbs. Try spacing your caloric intake evenly among 6 meals throughout the day. Need help on what to eat? Check out this link
If you want to preserve muscle, I would recommend a weightlifting program focused on basic compound movements, low reps, and heavy weight. This will help persuade your body to burn fat instead of muscle while you are in a caloric deficit.
If you want to do some cardio on top of this then go for it, but it is not required for losing fat. If you want to do cardio, I would recommend shorter, high intensity sessions instead of longer, lower intensity.
Finally, you could have just done a search. This question, or something similar to it, gets posted at least once a week.
Also, check out the link in my sig if you really want to get in depth with this. There are lots of knowledgable people on that board who would be more than happy to help beginners.
I swear, I need to make the "ATOT Bodybuilding/Physique Improvement sticky" or something.
great info thnx
