My Benchmarks
JPB
4,064
89
Originally posted by: videogames101
Why must it be amd-ati? I say intel-ati(amd)
Well, the biggest reason is that there are some awesome priced combos for the Phenoms.
I found one that has a Phenom 9950 + Antec Nine Hundred for $218.99. Which is $50 off the total price. :shocked:
Been looking through combos for days now.
Here it is. First combo on the page.
JPB
4,064
89
These are the combos I found that is worth considering.
Antec P182 = $169.99
Phenom 9850 = $169.00
M3A79-T = $188.99
G-Skill = $49.99
$577.97
_______________________________________________
M3A79-T = $188.99
G-Skill = $49.99
AMD Athlon 64 X2 5600+ = $79.99
$488.96
Phenom 9850 + Antec Nine Hundred combo = $218.99
M3A79-T = $188.99
G-Skill = $49.99
$457.97
Core 2 Duo E8500 + EVGA 750i FTW = $349.98
G-Skill = $49.99
Antec Nine Hundred = $99.99
$499.96
Intel Core 2 Duo E7300 + EVGA 750i = $289.98
G-Skill = $49.99
$439.00
Opinion on the best combo please ? :)
JPB
4,064
89
Oh, and before I get bad remarks about my thread, My doctor put me on something called Celexa because he says I have a chemical problem in the head :shocked:
Oh, and by the way, when I purchase the video card, it is going to be a HD4870.
JPB
4,064
89
Oops, you were right. Not sure how that happened. Edited list.
Syran
1,493
I'm gonna mix it up and say:
Intel Core 2 Duo E8500 + GIGABYTE GA-EP45-UD3P + GIGABYTE 2GB USB Flash Drive Gift= $309.98 ( -$20 MIR)
G-Skill = $49.99
$459.96 - $20 MIR = $439.96
Also, don't forget the 2.75% cash back from live.com :)
JPB
4,064
89
sao123
12,656
207
G-Skill = $49.99
So how does this sound........
Intel Core 2 Duo E8400
G.SKILL 4GB (2 x 2GB) DDR2 800
Antec P182 w. additional 20% off Promo code
Subtotal: $490.00
$470 AMIR
the P182 can be had from buy.com for $124.99 shipped... check teh hot deals section
JPB
4,064
89
Syran
1,493
Tons. Just from the extra memory and faster single core of the dual core processor. Windows should be much more responsive as well.
JPB
4,064
89
Syran,
Do you have the Gigabyte board that I ordered? If you do..do you have any problems with it and how does it run?
Overclocking abilities?
Syran
1,493
I've used Gigabyte boards in the past, Have 2 of their P35's, but not the newer P45. My current primary machine is running a DFI X48 that I got an insane deal on. I've been quite happy with the Gigabyte's, and have seen good reviews from both newegg and review sites on it (in fact, someone has one out today, check out the dailys for hardware reviews).
I do believe you will be happy. :)
JPB
4,064
89
I have another question :)
What is this I hear about Intel heatsinks require push pins for mounting ?
Ill be honest here, my last 7 computers has always been AMD and they always used different methods. So I have never heard of this push pin thing.
I have read several forums that people seem to have problems pushing them into their 775 board. And that some think you have to push way to hard and could possibly damage something. But some seem to say its easy.
Any thoughts on this? Since I know there are a gazillion intel users here. :)
By the way, This cpu will eventually be getting a aftermarket Zalman cooler.
lxskllr
60,935
11,265
I don't like the push pins, but they're Intel approved so you shouldn't damage anything. I used them on 1 build, and thought they were a PITA. I prefer screwing the HS down, but that requires removing the MB of course.
JPB
4,064
89
So you are saying the pins isnt required to use ? They can be screwed down if the mboard isnt in the case ?
JackMDS
29,563
432
In a new build it is much better to install the CPU and HSF when the motherboard is still out of the Case.
Then add card and memory connect it to a PSU and test that it boots before you put the Mobo into the case.
When the Mobo is Out on its static bag it is Not a problem to gently push the Pins.
P.S. If one has clumzy touch some one else can asked to it. It does not need computer knowledge to Push The Pins.
JPB
4,064
89
Yea, thanks for the replay JackMDS. I am pretty well knowledgeable with computers. Just have not owned an Intel before.
Thanks for the tips :thumbsup:
lxskllr
60,935
11,265
Just to clarify my comment. If the HS comes with pushpins I'd use them. They're usable, just not my preference. I prefer using screw on HSs from 3rd party manufacturers.
0roo0roo
64,795
84
pushpins seem flimsy but they do work. just make sure they are in full reset position and both the split tips are going through the hole before pushing down.
JPB
4,064
89
Thanks for the replies. I am considering however to get a Xigamtek Rifle cooler, or the Thermalright Ultra 120 Extreme.
I have read quite a few bad stories about the push pins. And I am not quite sure I want to deal with them.
