Or maybe mr. Phillips is right. But it's a pretty bold claim which goes against pretty much everything even I knew about weightlifting. The testgroup is small, but if every one of them shows the same results it does seem to be relevant. So is this true or is he seeking some media attention/extra funding?
Re-read what I posted above. This study proved absolutely nothing except protein synthesis was elevated higher at the 24 hr mark in the 30% max group than the 90% group after a single training bout. Overall volume has to be taken into consideration as well. I'd have to look at the study again, but IIRC 4 sets were done. a true 90% load would give you probably about 3 reps. Across 4 sets that's a whopping 12 reps. Good luck growing on 12 reps. A 30% load would give you quite a bit more volume (probably 15-30 reps/set).
I can't even believe the author would have to audacity to conclude progressive overload is false and high reps are better for hypertrophy after doing a study on one training session. Even if these were true, it's not proven by such a study.
I can only guess, but from what I understand it depends on what you want. If your primary concern is appearance then doing more reps will benefit you more.
Keep in mind this only works to a point, and eventually you just end up training muscular endurance. Also, even strength athletes will benefit from high-rep training from time to time, especially if they've been training for a while and have maxed out their neurological processes that contribute to strength, such as fiber recruitment, rate coding, technique, etc. In this case extra strength needs to be produced by an increase in cross sectional area (myofibrillar, sacroplasmic, and connective tissue hypertrophy.) The problem with very low rep training (1-3) is that there's not enough time under tension for much of a growth stimulus to occur. Likewise, bodybuilders can benefit from some low rep training to improve those neurological factors.
In very simple terms, getting stronger will aid in getting bigger and getting bigger will aid in getting stronger. Even powerlifters who are only really worried about their 1RM will train with higher rep ranges, and the biggest bodybuilders are usually quite strong. Maybe not 1RM strong since they don't train for it, but definitely strong.
Anyways, did 5x5 today, 10 sec pause in between...definately less stressful than 15/12/10, 30 sec pause. Maybe I should increase the weight a little. Or maybe stressful is not equivalent to efficient. I'll see how it goes the coming weeks.
If you did a 10 second pause between sets, you're not lifting heavy enough. Lowering reps does absolutely nothing for you if the load isn't increased.
