That's how you liberals are. You have a brain defect that makes you suppress fearful reactions to dangerous situations, reasoning with yourselves if the charging rhino warrants running up a tree when your conservative friends are already in the top branches hurling sticks at it. And when you're told about your mental condition you call that bloviating and armchair psychobabble. It so happens, however, that how you reason if you can reason, is based on your data base, the knowledge you've acquired on which to base your reason. In my case I reason in your dark because I have been to places you have not and absorbed information you do not know. I have sipped water from the well of idiots and fools as you would see them.
A fool convinced against his will is of the same opinion and there's no fool like a liberal who thinks a conservative can reason. You have no idea of the depth of my failure. I can't convince conservatives they are impervious to reason nor can I convince liberals about conservatives either. Both remain what they are, impervious to ego surrender and hapless ignorance where only love can flower.
