Isn't there already a thread on this, with these slides.
Anyone going to talk about the actual content of the OP? Like the rumoured specs that are listed?
The most interesting thing was the supposedly high density memory bus, with 512-bit taking up less space than 384-bit, which would be quite big if it's true, and could mean higher bandwidth on future cards without being too expensive from a die space POV.
Although it indicates that they can't get such high memory clocks with it since the clock speed for the RAM is lower.
*shrug*You were saying a couple of days ago that anything over 399$ is too much for a 290X - even for a card trading blows with Titan. I think you're just cheap, no offense or anything.
*shrug*
One man's cheap is another man's prudent.
Got one of the nicest 7970 models for ~$250. More than sufficient to run anything I'll be playing for the foreseeable future. And in two years when the 280X is that price, I'll consider getting one of those to replace it, if it's the best move at the time.
Anyhow, I too found that slide regarding 512bit bus taking less space than the memory bus on the 7970Ghz very interesting. I wonder how they managed to do that.
just have to say your $250 paradigm is some else's $2k's*shrug*
Hawaii GPU have been tested by a user on Chiphell. He didn`t specify which (290 or 290X) but it was tested with i7 3930K.
He scored X4487.
He have attached his screenshot in his post, but unregistered users can`t see it. And they have blocked people from registering :/
http://www.chiphell.com/thread-875687-1-1.html
There are no pictures in that thread of Firestrike results for 290 or 290X, just a post saying a score. I took a look through it all, the only pictures in the thread were:
Because you have to register I think. He have hidden the photo to unregistered users perhaps.
Also he didn`t test Firestrike. He tested 3DMark 11 Extreme preset.
So, $530 for R9 290 without BF4, $599 with BF4, $699 for R9 290X with BF4?
http://www.shopblt.com/search/order_id=%21ORDERID%21&s_max=25&t_all=1&s_all=R9+290
He scored X4487.
So about a 36% increase over 7970GE if true. That's actually faster than I was expecting.
