Originally posted by: RossMAN
Originally posted by: YOyoYOhowsDAjello
Don't make me break out the really expensive stuff links
I dare ya!
I dare ya!
Ok, you win
I don't feel like finding any right now heh. I've dealt with enough cables tonight already.
I dare ya!
Ok, you win
Do you want your pwn3ge pourage in a cup or bowl?
I dare ya!
Ok, you win
Ok fine... here
http://www.referenceaudiomods.com/Merch...D&Category_Code=CABLES&Product_Count=6
It's not a USB cable, but whatever
I dare ya!
Ok, you win
Ok fine... here
or how about a pitcher?
Originally posted by: state 08
Don't hate on the Monster USB cable until you've tried it.
I got my Monster 6ft USB cable at a steal for $69.99.
The guy at Bestbuy told me the gold plating on the ends will help transfer the files faster AND improve picture quality. He wasn't kidding!! A full Memory Card loads 15 seconds faster on to the computer, and I was going to buy a DSLR, but now I'm just going to stick with my Point and Shoot because the Monster USB cable improves the quality of the pics to level better than DSLR.
I dare ya!
Ok, you win
Ok fine... here
Originally posted by: shortspanishguy
Monster may be one of the most overrated companies I have ever seen.
Originally posted by: Acanthus
At least in that case the entire cable is of higher quality material. Silver is one of the worlds best conductors. And its not just plated on the jacks as a gimmick to make people think "gold is expensive, so it must be better!". Not defending the obscene price, just saying its better than monster, and obviously aimed at a market segment that will pay ludicrous prices.
gold doesn't tarnish, that is why its used on all sorts of connectors, including the pins on your CPU. you only need plating, because the interior metal isn't exposed to oxygen.
i was refuting your gimmick statement. gold is there to keep the contacts from oxidizing.Originally posted by: Acanthus
But it isnt silver underneath the gold... Its the same crap all of the other, cheaper cables are made of.
But that isnt what it says on the box...
The gold is there for performance/quality.
Ok fine... here
your contacts not corroding and rusting themselves together doesn't improve performance/quality? i'm not certain on this, but i'd imagine that the signal would be seriously degraded when trying to send it through rust, if it'd even work at all.
Ok fine... here
Uh... they don't even explain why it's so expensive? Is the cable cryo treated or something? Without any more information, I bet a DIYer could build that cable for something like $200 or so.
Unless litz braiding is more expensive than I thought it was.
EDIT: oh wait. On that same site, I found this. Unless you speaker guys are absolutely crazy, I think that site's all about the snake oil.
Ok fine... here
If you're into DIY, you can make your own knobs
http://www.referenceaudiomods.com/Merch...=CTGY&Store_Code=RAM&Category_Code=C37
:laugh:
Audiophiles are crazy (at least the crazy ones) :shiftyeyes;
Ok fine... here
:laugh:
