How noisy is the fan that comes with it at $6?
Quote
35C is a little steep for the system temperature. One or two case fans can make it nicer.
What do you base that on? And WHY would I want to get it any lower?
28dBA -- which is about equal to a typical case fan. Or, what can I say, fairly quiet?
Me too1 I pimp their page whenever I can. Between them and Newegg I dont go much anywhere else.Originally posted by: Evadman
I love SVC.
Sounds really poor. Every cooler that SVC has should outperform that. GC68 is not labelled for XP 2100, with a reason. You better choose another fan for that heatsink and use the default fan as a case fan which it is really. You just might need a case fan.i have a xp2100+ with retail heatsink...
by changing to this heatsink, is it gonna help a lot.
the temp of my cpu is around 50 just idling, almost went to 60 when i backup a dvd yesterday.
Depends on two things: your case temp and the power of the fan you choose. Mine runs my xp1700 at 13C above case temp. If I were you I'd opt for the $4.99 variable speed fan and adjust it as needed. I'd bet you'll get a good improvement.Originally posted by: hola
Originally posted by: cheapgoose
the only way you can make shopping at svc sweeter is living a mile from them. I pick up all my orders, eventhough their shipping's pretty good.
I love SVC.
Right now they have a humungous tube of AS Alumina for ~$6.50 shipped reg mail:
14 gram tube of Alumina @ SVC!
I got mine last week. Make sure you use reg mail, not priority to get this price! I never order priority from them but I always get my stuff within 3 days and usually 2 from when I place my order. nuff said...
Artic Silver 3 can outperform Alumina by about 1-2C if applied properly. Artic Silver is a bit messier, original version is electrically conductive, version version 2 is very little electrically conductive, version 3 is not. Alumina is not conductive and it is easier to clean. AS 3 is the best.whats the diffrence between Alumina and Silver III? any one?
First it would decrease the temperature of all your components, not only CPU but PSU, hard drives, memory, graphic cards etc. For example 5C difference means considerable extended lifetime (MTBF) for these components. Isn't that argument enough?
Quote
LMAO!
The igloo has a 4600rpm 60cm fan that may provide similar cooling to the GC68's fan but IMHO there's no way it could be as quiet as the stock GC68 2500rpm 80cm fan. I've done a lot of experimenting with heatsinks/fans and the reason why the GC works so well is that it is a large heatsink with a large fan (duh!). I just know to look at the igloo heatsink can't be as good a cooler and so much rely on a faster (and louder) fan.Originally posted by: drti
good alternative at same or better price... imho, the glacialtech igloo 2310 is quieter and perform as good as the svc, if not better.
Does the SVC GC68 come with a fan grill as well? Also, what do u think is better, svc's gc68 with 32cfm/29dba or newegg's version with 38cfm/33dba?
Originally posted by: stevejst
Perhaps you did not notice but here is the info that might help you to realize the comparisons.
GC68 is Chinese made Galaxy (GC as in Galaxy Cooler) brand, not SVC, OEM for YS-Tech, exported and used in AoC D5-825 coolers (with faster fan, check newegg), and Akasa 823 and 824 coolers. Akasa uses the same quality fan in 824 version as GC68 default in SVC. So here is a comparative review of a number of coolers including Akasa 824.
Review
Notice, Akasa 824 is third from the top of graphs. This test is performed honestly, with results as you see at the serious overclocking of T'bred 2200 at 1915 MHz (115 over default). This processor uses 68W and generates less heat than XP 2100 Palomino core. I think it is clearly visible that AX-7 outperforms Galaxy, and Pal 8045 significantly outperforms both of them. So you get what you payed for.
These are not the best heatsinks money can buy on retail. Talking about Akasa, you need to know this is an entry level XP cooler for Akasa. Akasa does make much better quality heatsinks as well and, of course, they are more expensive.
The question is whether this GC68 cooler can cool the Athlon XP 2100 Palomino, the way it is. After reading this review I think the answer is obvious.
GC68 certainly is not the best cooler but maybe the best for the money, according to the post here. And if it could cool XP Tbred 2200 @1.915MHz @1.92v, answer is OBVIOUS whether it could cool XP2100.
