tinpanalley
Ok, that's what I thought. Plus, removing them later through that spackle could tear out an even bigger chunk of plaster, I imagine.The spackle wouldn't and any structural integrity.
It's too late for me now to unscrew these and add a washer, right? Once concrete screws go in that's it, you can' re-set them?My concerns with the current setup is that the head of the screw might not have enough 'lip' to keep the wire truly secure behind it.
Oh, it's solid. I mean the tip wiggles by a mm or so if you use force but I think that's due to the 1/4" sticking out and the 5/8" in the loose plaster. The one on the right can go a bit farther because I drilled the hole a bit too far.Also, there's no clamping force exerted between the wall and the head. Is it solid in the hole? The old hole may be compromised. You can tell if you sink the screw but it just spins and doesn't bite.
When you say "the old hole", what are you referring to? The one below? That hole goes down on a 45degree angle not on a straight angle into the wall. And it's far enough down.
