lxskllr
- Nov 30, 2004
- 59,996
- 10,476
- 126
It has to do with the fact that you're a pious little shithead.
Hmm... Pious?
The only correct way to warm up a vehicle is to drive it, but the argument about warming up the truck in winter at lake tahoe was about IDLING a vehicle to warm it up. You can't idle a vehicle to warm it up and expect the tire pressure to go up. You want to warm up your tires and the car, you drive it because doing it any other way is stupid.Graph them together. I bet as you drive both go up together then back down together when you park.
<Raise hand>
Um, stupid question....what is "inflate to sidewall"?
I know it refers to tires, but is "inflate to sidewall" = "inflate to the pressure indicated on the outside of the tire"?
So, not to be Fleabag2 here, but why is it a bad idea to inflate a tire to the pressure indicated on the label? To what pressure should it be inflated? Wouldn't they label it with a safe pressure?Yea, to the maximum pressure stated on the side.
It refers to the fact that users on this board go into a heated discussion about NOT inflating their tires until the sidewall was at the proper height. They said that they could tell when the tires were "inflated to sidewall" when they observed the tires from the outside but it turns out they are wrong and that the only way to know the tire's pressure is when you use a pressure gauge.<Raise hand>
(Maybe these questions are answered in the original fleabag thread which started it all....might anyone have a link handy?)
Well if that happens, possibly you added too much air.. Though the best part about adding more air to the tires is that it reduces the likelihood of hydroplaning. I've never found what you've said to occur in straight line braking, but what I have found is that one shouldn't take corners too quickly when it's slick outside, otherwise you might end up kissing the curb.Inflating to max pressure COLD will give you better gas mileage and a firmer ride at the expense of a bit less rubber on the road. You may have more of a tendency to slip, especially in wet or snow.
that confused me as well
Are you implying that when I turn the air on to hot in my car in the winter time that it's toxic?? And, since you're Mr. maximize efficiency, you realize that engines are more efficient at higher temperatures, right? That's one of the reasons engineers spent years trying to develop ceramic engines.Regardless of whether or not it would work at lake tahoe in winter, the bigger problem would be the coolant's toxicity. But even if you had a heat exchanger with a heat exchanger, there would be too much heat loss, not to mention the fact that coolant temperatures rarely get that high in the coolant alone, let alone when you have the loss between two heat exchangers.
Oh and for the asshats that are going to say, "but my car's temperature regularly gets to 230F", I don't give a shit about your crappy corvette or any other such vehicle for that matter because.
Are you dumb?
Resistive heating is 100% efficient, and most of it ends up in the water. There will be a small loss in the wiring, and some heat leaking from the pot, but the vast majority will be in the water. It's like taking a pot and sticking the stove burner inside it.
lower voltage? I don't see the relevance. I2R losses in the wiring are damn near zero (which is why the cord doesn't melt).
Are we trying to boil water or are we cooking food?I'm thinking the most efficient way, energywise, to bring water to a boil would be by reducing the pressure above the water to near vacuum.
The label on the tire and the label on the car have two different meanings. The tire's max pressure loosely indicates how much weight the tires can theoretically hold. You want the tires to remain flat and have a lot of surface on the road, so a combination of this expected area and max sidewall pressure indicates how much weight is on that tire. the car's pressure spec is similar but the opposite. the car company knows how much weight will be on that tire and they know how much surface area the tire needs to be safe, so a combination of that will tell you the ideal pressure for this particular car.So, not to be Fleabag2 here, but why is it a bad idea to inflate a tire to the pressure indicated on the label? To what pressure should it be inflated? Wouldn't they label it with a safe pressure?
Higher temp doesn't always mean more efficient, but engines definitely have a preferred temperature. My Corolla drives like fuck when it's cold, but it only drives like shit once it's warmed up, so cold is obviously bad. Similarly, if an engine is too hot, fuel will detonate too fast and the engine will begin to knock. Too hot is also bad. We established how this works in that garage thread about the 1000HP car that is hard to drive. It's a really interesting threadAre you implying that when I turn the air on to hot in my car in the winter time that it's toxic?? And, since you're Mr. maximize efficiency, you realize that engines are more efficient at higher temperatures, right? That's one of the reasons engineers spent years trying to develop ceramic engines.
Very nice. Though you need to have the pots/pans for it or buy new.
