Paintballfreak66
Originally posted by: GuitarDaddy
Bummer, sorry to hear of all your troubles. It could well be your PS, have you checked the voltages on the three rails 12v 5v and 3.3v using Asus probe under load? Generic PS's are generally bad news for O/C even if they have a high wattage ratting.
I would also try Priming with 250mhz HTT, a low multi like 8, and DDR200 mem setting. If you still get errors in prime, this could be an indication that the board isn't getting enough stable voltage to sustain a high HTT. Where you able to run high HTT with your previous CPU?
If you think memory timings could be the problem, loosen them up to like 3-4-4-10.
Keep your chin up and keep pluggin🙂 you will eventually find the problem
my timings were already @ 3-4-410 lol. I used this psu on a p4 cpu and only had my fsb @ like 150. I'm getting a new psu and a pair of ddr500 512 mb because one of my comp buddies said that sometimes with new mobos your memory need a partner to rebound off of in case something fails on one module, or something to that extent. I already tried lowering the memory setting and I still got the errors so maybe it is the psu. anyways thanks for the help, I'll be sure to update when I get my new stuff. thanks
EDIT: and omfg I almost broke my mobo in half trying to install that godforsaken stock heatsink from amd. geeez my finger is going to hurt for weeks
