Depending on how deep you want to jump into this MD community, there are two or three routes you can take.
You can buy a player/recorder. All you need is another cd player with optical out and you'll be set. The player/recorder also comes in handy when you want to go record something, bring a mic with you and hook it up to the line in.
You can get a player/recorder and a player. That way, you can use the player/recorder to record from the cd, and then pop it into your player if you really want the smallest size possible.
You could get a table system and just a player. That way, you can listen to md's at home without having to connect your player/recorder to the speakers. Of course, you lose the ability to record on the road...
I started with a player/recorder and cd. MZ-R50. That thing was one of the best player/recorders made. But rather large. As they started to cram the players/recorders into smaller packages, some small problems have popped up (read it in an article written by some MD repair man at
www.minidisc.org). I still have that thing, but rarely used. I'm currently using a small stylish JVC table system and an Onkyo portable player... by the way, I forgot to mention that you could also get the Live!Drive IR with the Platinum 5.1. That thing has optical output, so you could forget all about buying a separate cd player with optical out. I haven't really used it much, but make sure you turn off all other sounds when recording from Winamp. I forgot about my buddylist and when someone imed me you could hear the chime during the music.
