blackened23
Nice setup, M3t4lh34d/BossToss. :thumbsup: Why have all of your posts since you rejoined been "hey guys, I have FOUR 680s FOUR 680s FOUR 680s"? lol we know bro.
lol wow. Why does he keep changing his name?
Hopefully Nvidia works on the scaling for MP2, as my 4 680s only see moderate usage in BF3. Most other games fail to make use of 2 of them, much less 4. And yes, I'm running high res with a 3930K @ 4.7ghz, so thats not it ;x
Boxed Copy of MP3 is in order 35GB or 8 DVDs ROFLMAOI have just moved house and have gone from a 50mbit cable connection to a 15mbit adsl one. I was wondering if I really needed 50mbit, that was until I saw the download size of Max Payne 3! 30gb! I wonder how large Doom 4 will be on Steam.
As for the game, I am glad that it is one that starts to push the hardware requirements of the PC hardware, not just gfx wise but memory wise as well. I have never played any of the Max Payne games and am looking forward to trying it out.
I'm just glad I didn't use my ssd for games, I just use it for os and applicaitons. Rage and Max Payne 3 popping 50gb just between the two of them and newer games are likely to be larger. I still think there is a lot of life in hard drives with such large games comming out.
I'm not sure how chimaxi would connect him to this: http://forums.anandtech.com/showpost.php?p=22652581&postcount=12
Whoa... The game seems very GPU bound. 3770K from 2.5GHz to 4.5GHz... frame rates are the same at 1920x1080.TechSpot has just posted a detailed performance review of MP3: http://www.techspot.com/review/537-max-payne-3-performance/
Looks like mid/upper-range cards from the last-gen can comfortably play this game at the highest quality levels.
They tested CPU performance during a cut scene. It's actually pathetic that you can be that incompetent and still write for a tech site. Test it again when Max Payne is shooting up half the level and then we can see some meaningful numbers.Whoa... The game seems very GPU bound. 3770K from 2.5GHz to 4.5GHz... frame rates are the same at 1920x1080.
Indeed. I didn't notice it either. Was too quick scheming through the graphs. HeheHmmm, I didn't notice that when I posted the link. Definitely a weak test of CPU scaling.
With an OC on that 8150 is would be up at the top of the pile LOL everyone knows you have to OC a Bulldozer for it to perform don't judge it based on it stock performance.Wow, more fail for bulldozer.
A CPU will not make the game get more frames per second period and all the OCing on the AMD CPUs will do is alleviate the bottle neck and put it back onto the GPU where you want it to be. You will not see much more if any frame rates if you are OCing the Intel 2600K because it is already feeding the GPU to the max. The 8150 should catch up to the stock clocked 2600K in this game when it is OCed to around 4.5Ghz or more.Yeah cuz none of the other processors can OC, particularly the K series right?🙄 sorry stock is exactly how it sold be judged. 2 additional cores and a higher clock speed and being out performed by the X6.... Never mind the Intel CPUs
