Originally posted by: Born2bwire
Originally posted by: steppinthrax
I you read the article it mentions "Alexis Lemaire trains for around four hours per day, practising calculations and memorising thousands of tables of numbers" There are a lot of patterns that are related to each other when doing calculations. A good example is multiplying by 9. In grade school many were taught when doing multiplication facts when multiplying by 9 the first digit in the answer is always one less than the number other than 9.
Example
9 x 2 = [1]8
9 x 3 = [2]7
9 x 4 = [3]6.
This is a very simple relationship but there are much much more complicated relationships when making complicated calculations. So in other words if you memorize most if not all of those relationships and find new patterns out yourself you can effectivley work out large numbers. So I highly doubt he calculated this from scratch. He looked at the digits and could deduct relationships of what the root could be......
Another one is calculating the square of numbers around 50. You take 2500, subtract a 100 times the difference between 50 and the number. Then you just add a correction that is equal to the square of the difference.
45: 2500-500+25 = 2025
57: 2500+700+49 = 3249
And so on. It's an easy relationship that you can derive from taking the square of (50-a) and stuff like that. It comes out: (50-a)^2 = 50^2-100*a+a^2 and 50 just happens to be an easy number to remember.
