How? Explain
what does the area on the left side of the parabola with limited range have to do with the series on the right side with a range of infinity?
How? Explain
His wording is poor, yes. The function is still sound, however. At the same time, it isn't really true to say that "infinity is never ending." Infinity is a constant. It isn't a rolling counter that is currently running and will never stop.i've watched the first 20 seconds of the video and already see a major flaw...
he says "all the numbers 1 + 2 + 3 + ... all the way up to infinity".
the problem is ... there is no such thing as "all the way up to infinity" as infinity is never ending.
The result of 1/2 isn't strictly arrived at by "just taking the average." That's just the simplification he used in the video, while linking to another video that proves that 1/2 is the valid sum.don't even know if it's worth while watching the rest of the video with the premise of it being so wrong. he has the basic concept of infinity wrong from the get go.
it is just like how infinity + infinity = infinity.
or infinity * infinity = infinity
all it means is never ending numbers.
EDIT:
lol wow this video is retarded, not watching if after seeing what they say the sum of S1 = .5.
you can't take an average of a never ending sequence of numbers. but they conveniently do just to "prove" their point.
simply retarded.
An infinite series of "A"s followed by a "B" would NEVER have a "B".
"Never ending" implies that it a process is underway. But there is no process. A quantity is finite or it is infinite, but it remains a fixed value.i don't think you grasp what infinity means.
http://www.mathsisfun.com/numbers/infinity.html
it is a concept of a never ending number.
"Does not have an end" is not the same as "goes on forever and ever." It isn't on-going. It is already infinite. It didn't "arrive" there. It isn't "on the way" to something. It simply is infinite. Constantly.....it is not a "constant" as you say. it is a concept of a number that is never ending and has no finite end and goes on forever and ever.
No. Maybe it you'd prefer that I refer to it as a "value." It isn't really accurate to say that 0.333... repeats "infinity times." There are an infinite number of 3's. They are all there, already. They aren't "still going."...just like 1/3 is .333 repeating forever. it repeats infinity times, ie., it never stops repeating.
The series represented is a whole. It is an ordered set with no greatest element, but it is a set nonetheless.EDIT:
some of the examples on that page are good, especially this one kind of fits this whole stupid video...
just like the "infinite series of 1 + 1 - 1 +..." would never "end" so you can never have an average/summation of 1/2.
This is somewhat just a difference in semantics, but you need to understand that infinity is a mathematical object -- specifically a type of set. It isn't a process. It is already whole.just like there are "infinite" points in a line. the amount of points in a line never ends because you can be at .1, .01, .001, ...
What system are you working with that you claim infinity is a constant?
you clearly don't grasp the concept of infinity. i'll agree to disagree.
Infinity does not grow
Infinity is not "getting larger", it is already fully formed.
Sometimes people (including me) say it "goes on and on" which sounds like it is growing somehow. But infinity does not do anything, it just is.
No, really. I do. The things I said were even included in the link you offered.
If it isn't growing, then it is constant. It is not finite, it is infinite, constantly.
You said it "goes on forever and ever," and "it never stops." These are false statements. Infinite sets are not "never ending." They are complete. They are whole.i never said "its always growing" i said "it is never ending".
Strictly speaking, that isn't what he did. If you click on to the next video where the result of 1/2 is explained, you'd understand it.you simply cannot take an average of something that is never ending, because the sum of the numbers in the group you want to take an average of, is divided by the size of that group, which has to be a finite number.
Again, infinite numbers are not "never ending."...you can't put a never ending number as the denominator to find an average.
Your incredulity does not invalidate the math.so their idea of finding an average sum of 1/2 of an infinite set simply makes 0 sense.
Actually there are infinitely many infinite constants. Take the Aleph numbers, for example.and no, infinity is NOT a constant.
The value of Aleph_null is the same everywhere....a constant means that the value means the same thing everywhere.
No, that is not the case. That is only true of finite constants....if that were the case, then infinity/infinity would equal 1,
Your ideas seem to be a case of "garbage in, garbage out."...and it doesn't. it equals infinity, as that link i pasted shows.
You're using operations defined on finite numbers, so the mistake is yours, not mine.if infinity were a constant, then infinity + infinity would equal 2 * infinity, which it doesn't. it equals infinity.
What is Infinity?
Infinity ...
... it's not big ...
... it's not huge ...
... it's not tremendously large ...
... it's not extremely humongously enormous ...
... it's ...
Endless!
Infinity has no end
Infinity is the idea of something that has no end.
In our world we don't have anything like it. So we imagine traveling on and on, trying hard to get there, but that is not actually infinity.
So don't think like that (it just hurts your brain!). Just think "endless", or "boundless".
If there is no reason something should stop, then it is infinite.
No, really. I'm not. "It has no end" is just lay-speak for "the set has no greatest element." The set isn't still growing, however. It is whole. It is complete. All of the elements are already there at the same time.you are just flat out wrong.
I grasp it quite clearly. I can also see quite clearly that you have misunderstood your own references.i'm sorry if you can't grasp this concept.
This isn't really true. It implies that if a process went on long enough it would "reach infinity," and that's false.If there is no reason something should stop, then it is infinite.
never-ending
[nev-er-en-ding] Spell Syllables
Examples
adjective
1.
having or likely to have no end:
No, I'm saying that "never ending" describes a process while "has no end" describes an object. Infinite numbers are mathematical objects. They are not processes. When you speak about infinity as though it were a process, you are speaking wrongly.so now you are arguing that "endless" and "never ending" and "has no end" all mean different things?
http://dictionary.reference.com/browse/never-ending
Infinity is not a common-sense idea, but it is well-understood. It is easy to have some wrong ideas about infinity if you try to think about it in common-sense ways.yeah i'll agree to disagree with you. you aren't making any sense at all to me. we'll leave it at that![]()
What is This thread? This thread ... ... it's not big ... ... it's not huge ... ... it's not tremendously large ... ... it's not extremely humongously enormous ... ... it's ... Endless!
Nope. Nope nope nope nope. Infinite sets are never ending.
don't even bother dude it's not worth it lol.
