Massive Meteor Shower -Activates Russian Nuke Defense Systems
Nintendesert
7,761
Small chance - sort of.
We had an airburst over Tunguska a bit over 100 years ago, and that flattened a large swath of forest. Now we just saw another airburst that caused a good bit of damage.
Yes, those are small objects, with relatively low consequences. Maybe "just" a city lost if they'd hit.
The other half of that coin of risk is the consequences. There's a low risk of it happening during our lifetime, high risk of it happening at all, and potentially-cataclysmic consequences if it does happen.
1) Development of the technology to detect and deflect asteroids would surely lead to benefits for us. Flying people to the Moon and back would seem to have few practical benefits, but it was an excellent PR campaign for the STEM fields. "Defend Earth and humanity from deadly space rocks!" Maybe it won't attract quite the attention as a Moon shot, but it's still something to get people interested in those fields, and likely generate some interesting new technology and scientific knowledge.
2) Who says NASA's budget will be decreased? This could just as well boost their budget considerably. Now, yes, you'd have to watch how that budget is allocated; I'd also hate to see things like the missions to Mars or Jupiter's moons suffer as a result. Those produce valuable findings as well.
....Yet you're here saying that we'd be wasting money if we'd try to prevent that very thing.
So is your ideal route to a good asteroid deflection program to simply wait until something hits us good and hard, wipes out 10% of the population, and then try to figure out how to prevent the problem again? Of course, if our ability to launch any manner of spacecraft was destroyed or disabled during the impact, I guess there'd be no point to even starting research on a deflection project until launch capability was restored. :hmm:
Yeah...momentum's a bitch.
Let's convince a 150-ton rock, moving at 50,000mph, that it really needs to stop moving in the particular straight line that it's on.
That's going to take a lot of effort.
Well government is reactionary. Look at our posture before 9/11 and look at it afterwards. Space rocks are going to be the exact same way. Government has limited resources and right now we're even looking at mandatory cuts and a lot of people being put out of work over the budget. Funding stuff like this is simply not going to happen. That's just the truth of the situation.
I agree with you that eventually it's a 100% chance that it will happen. Sometime. All things geologic and in astronomy eventually hit that point. Our planet will freeze over again, then it'll get really hot and do it over and over again. We'll get hit be a big planet killer eventually. The point is whether it's likely to happen in our lifetime or even anytime remotely close our lifetimes. The answer is highly skewed to the no side.
NASA's budget keeps getting slashed, it's a pittance of what it should be.
As it stands the risk isn't high enough to justify the expenditure from established science. We can't even fund our particle accelerators anymore. :|
I simply feel as things are right now, budget wise overall, scientific budgets and the odds of stuff like this happening more often and the methods we have for even defending against this stuff the money is better spent elsewhere on things that can further advance us and save more lives with that same money.
rockyct
6,656
32
There were two contrails, it split up.
I'm saying more than the two dashcam videos that showed the entire meteorite entering the atmosphere and burning up. There were two that were online after only a couple hours and they are still the best I've seen.
klinc
555
Sonic boom was the shock wave and it wasn't part of any explosion. When the shock wave disappears it goes below the speed of sound and cause its so high up most of it comes down frozen.
CZroe
24,195
857
It would have going for it the high relative speeds, so it wouldn't be exposed to the superheated air for very long at all. It would also need to first heat and then strip away enough of the missile's exterior to expose and disable the guts.
Also, all I can't help but think about now is an episode of Stargate: SG1 where they visited a planet that experienced a periodic meteor shower, but they were getting closer and closer each year. Their "close calls" lacked sonic booms or destructive blast waves.
Oh well. :p
Clearly, different materials dominate their solar system. Part of what made this blow up is the dissimilar materials that make it up combined with sudden and uneven heating.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
Actually, it's inertia that's a bitch. You only need a very very tiny change in momentum (actually, the velocity component of momentum.) But, these objects have a tremendous amount of inertia. (Inertia being the property that resists changes in momentum; it's equivalent to mass.)
Jeff7
41,596
20
:hmm:
Yesterday, my high school physics teacher died a little inside. :(
In Soviet Russia, space travels to YOU.
Sure as hell makes it a lot cheaper though.
Oddly enough, it sounds like our objectives on this stuff aren't too terribly far off - we both want to see NASA funded, anyway. I'd like to see more spent on asteroid defense systems, at least to get something started there. (Our Defense spending is currently with the objective of defending us against our own species...however pathetic that notion is in itself.)
Going against that reactionary trend would certainly be a welcome change, and embrace the notion of prevention.
"Government has limited resources and right now we're even looking at mandatory cuts and a lot of people being put out of work over the budget."
One view is that those people being put out of work were given work unnecessarily. The private sector will lay off people when there is no longer a need for them - it's done (theoretically) for efficiency purposes, or just to net someone some nice paycheck increases for slashing expenses, and expecting the remaining workforce to magically pick up the slack.
That latter point aside, government, at least in the US, has a tendency toward bloat and inefficiency, which certainly tends to screw with the ability to determine what functions it should have.
"The point is whether it's likely to happen in our lifetime or even anytime remotely close our lifetimes. The answer is highly skewed to the no side."
There have also been a number of expensive things done before my lifetime that I'm glad we've got, and I'm sure you could say the same as well. For example, the space program itself: Started before I was born; or the interstate highway system; or even the simpler things, like the city I live in. I'm sure starting and maintaining a city is no cheap thing, but someone had to bear those costs at some point, and it wasn't me.
People not yet born may well appreciate the foresight of generations before who did decide to keep them safe from something with a high probability of eventually happening.
"NASA's budget keeps getting slashed, it's a pittance of what it should be.
Also a pretty sad state. I'm sure if you ran a survey on what portion of their tax dollars go to NASA, most people would put it at a much higher level than it actually is.
I tried an informal survey like this back in college as part of a project for one of my "arts credits" filler courses. Unfortunately, my wording of it caused it to be rendered useless, as I had presumed that people in the class would know the difference between million, billion, and trillion.
Yes, I did say "college."
Pure science has little regard anymore, as you've evidently seen as well.
To any who say that science with no immediate practical application in sight is useless, Carl Sagan already explained it.
(The short, short version: Study of the electron, and how electrons interact with magnetic fields, was once one of those "useless" wastes of time. Good thing we kept studying those tiny particles and invisible fields.)
And for the heck of it, I'll throw in this testimony by Neil deGrasse Tyson.
The Universe anticipated the vacuum that would be created by Sagan's death, so now we've got him. :)
"I simply feel as things are right now, budget wise overall, scientific budgets and the odds of stuff like this happening more often and the methods we have for even defending against this stuff the money is better spent elsewhere on things that can further advance us and save more lives with that same money."
All it would take is preventing the impact of a single extinction-level asteroid to seriously skew that "save more lives" figure though.
