Originally posted by: DivideBYZero
Originally posted by: Marlin1975
Originally posted by: edro13
Wow... I didn't think a bullet had that much forcing falling back down. I thought Myth Busters debunked that using coins? Does the bullet have a certain set velocity rate when it is falling?
A bullet will have the same speed going up as it does coming down. SO if it travels at 100mph out of the gun that is 5 feet off the ground, it will also be travling at 100mph when it comes down at around the same level it left off at, 5 feet. Now of course it may change depending on angle, wind speed, and other factors. But none the less, a bullet goes up, it must come down.
Proof that a little knowledge of something complicated rarely leads one to an understanding of the topic
Here is a article written about it.
http://www.straightdope.com/classics/a950414b.html
Just backs up what I was getting into, if in a vacuum then it will be the same speed, BUT because of resistance of the air, its terminal velocity, it will be slower, but still enough to probable hurt and/or kill ya.
No. If you fire a projectile vertically from a gravity source then the rules of terminal velocity will still apply. The gravity would only have a certain force on the object, when it loses all it's kinetic energy. It would begin to be drawn by gravity, the object would reach TV and once reached it would accelerate no more.
The object cannot have 'velocity memory' such as you suggest in the first post.
Somebody correct me if I'm wrong.
Yup.... correct..... the bullet will not exceed TV, which is much less than the initial velocity when fired from the gun.
