tyler811
- Jan 27, 2002
- 5,385
- 0
- 71
Originally posted by: naruto1988
wow. just wow. i always thought this would happen someday.
Originally posted by: glugglug
If done properly, firing a bullet into the air is completely safe. That is, you have to fire it close to straight up -- it will stay up longer and the air resistance will have more time to slow it down before it falls.
This guy fired it much closer to horizontal, which is how the bullet traveled over a mile horizontally on it's way up & down, which means less rise and fall time since the vertical component of the path is so much smaller, and less time for it to slow down.
Edit: well, not completely safe, but a bullet fired vertically will come back down slow enough to just cause minor injuries, like getting hit by a rock, not fatalities.
are you majoring in dumbass? tell you what. let me get a penny go untop of the sears tower and drop it on your head. im willing to bet you would die.
Originally posted by: SludgeFactory
well I know it's been debated here before, and IIRC there was a military study done on it that showed if the bullet is fired vertically then it's not that dangerous. (rh71 linked that very thread!)Originally posted by: edro13
Wow... I didn't think a bullet had that much forcing falling back down. I thought Myth Busters debunked that using coins? Does the bullet have a certain set velocity rate when it is falling?
A bullet will have the same speed going up as it does coming down. SO if it travels at 100mph out of the gun that is 5 feet off the ground, it will also be travling at 100mph when it comes down at around the same level it left off at, 5 feet. Now of course it may change depending on angle, wind speed, and other factors. But none the less, a bullet goes up, it must come down.
Proof that a little knowledge of something complicated rarely leads one to an understanding of the topic
Here is a article written about it.
http://www.straightdope.com/classics/a950414b.html
Just backs up what I was getting into, if in a vacuum then it will be the same speed, BUT because of resistance of the air, its terminal velocity, it will be slower, but still enough to probable hurt and/or kill ya.
The TV show "Mythbusters" did an episode on that.Originally posted by: Citrix
Originally posted by: DrPizza
Yeah, Mythbusters is a great show and all...
But if you guys think that they get everything 100% correct all the time...
It's entertainment more than anything. I didn't see the penny episode though... can someone tell me what they did?
While I highly doubt a penny would kill someone (dropped from a tall building), determining what a penny will do after 1 or 2 trials ignores that there might be a large degree of variability in the problem.
Taking mythbusters as preaching the gospel in science is on a par with the example above of someone who took a high school physics course (where frictional effects are generally ignored because of the complexity of taking them into account in most situations) who thought the penny would have a net acceleration of 9.8 m/s/s down the entire time. I'm not an expert in science (though I know quite a bit), and I enjoy watching mythbusters... but I have noticed a few minor errors along the way. There are some shows that students have told me about that I'd love to watch...
torrent link anyone?![]()
Originally posted by: rh71
I'm skeptical about this... what happened to 9.8m/s^2... that wouldn't apply going both ways... only 1... coming back down.Originally posted by: Marlin1975
Originally posted by: FrankyJunior
They did a CSI episode about this too.
That's why it's illegal to shoot firearms within city limits....
It's not nearly enough to go through your skull. It would hurt like hell, but that's about all.
It's been a while since I saw that episode, but I thought they ended up figuring out how much force a penny would hit the person with, then went way beyond that number.
Absolutely. I'm not arguing that a bullet won't kill someone if it falls and hits them. I know for a fact that it can kill people.Originally posted by: BlinderBomber
But doesn't a bullet weigh more than a penny and isn't it more airodynamic (sp?) so wouldn't it travel faster than a penny?
This is why you are wrong. You can't ignore anything. This isn't high school physics here.Originally posted by: NogginBoink
Actually, the bullet acellerates at 9.8m/s^2 both going up and coming down. What do you think makes the bullet slow down as it goes up? Hint: it's slowing down at 9.8 m/s^2.
Ignoring wind resistance, the bullet will be traveling at the same speed when it hits the ground as it was when it was fired straight up. Marlin is correct.
Basically if shot straight up, the impulse from the explosion of gunpowder creates an initial velocity much higher than whatever drag-limited terminal velocity the bullet achieves on the way back down. As you fire in a more horizontal direction, you would bleed off less of that inital velocity before you hit an object on the ground and have more penetrating energy.
The problem with drunken gun-firing bastards on New Year's is that they're not carefully calculating the trajectory of their bullets and more likely firing at ~45 degrees and into somebody's house down the block.
Bullets will exit from a gun traveling faster than terminal velocity. Both gravity and friction due to movement through the air are working on the bullet, so you are wrong in your claim that it is slowing at a constant 9.8 m/s^2. In truth it will hit the ground with a smaller velocity than when it exited the barrel of the gun.
