making a NAS/Plex server, need opinions
sactoking
7,649
2,925
Thanks for the info. I haven't quite got Plex set up yet (didn't have a lot of time yesterday to mess with it) so that's helpful... I'll go the docker route. Since I'll really only need to use the Plex UI for the initial setup, the slow UI shouldn't be a problem.
I had to change a lot of the sort tags on my movies, so the slow UI through Docker was a frustration then. I wanted the eight harry potter movies to sort sequentially and not by title, I like grouping movies by relationship even if they're not direct sequels (The Amazing Spider-man 1 and 2 sorted with Spider-Man 1-3) and some movie series don't group properly by title (The Fast and the Furious, 2 Fast 2 Furious, Fast Five, Fast and Furious, etc.).
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
Ah, that makes sense. My collection isn't too big yet to deal with that stuff.
I have Plex running successfully and I just started copying everything again. I haven't had to deal with too much yet, but the docker UI for Plex doesn't seem that slow. Works pretty well.
Thanks everyone for their tips and recommendations.
JoeMcJoe
327
Look at the price of something like a QNAP TS-451 with its built in Plex server, might end up being cheaper, and it does RAID well.
ControlD
5,440
44
The problem with those types of devices is that the Plex implementation tends to be somewhat limited. I played around a little bit with a Synology and it couldn't do any transcoding at all. The CPU in that thing was just not powerful enough. With my low budget unRAID server built around a G530, I can simply store all of my movies as mkv's and transcode as needed to whatever device I want to watch with.
I also have not noticed the Plex docker being slow to work with. Maybe it depends on how large the library is though.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
Also, those prebuilt NAS devices are expensive. They are rarely the cheapest option if you have the knowhow to build it yourself. In my case, I didn't even need to build it myself. The Lenovo TS140 tower I ordered was pre-built with a Xeon E3-1225 processor, 4gig of ram, a 500GB HDD and DVD drive. It was only $285, and the case it's in is quite nice to work with. Mostly toolless with extra fans to keep the drives cool.
Compare that to the TS-451 which is going for ~$450. Don't get me wrong, the QNAP devices are a lot more compact and very good devices for getting a NAS running without problems. I have a QNAP TS-212 right now which is what I'm replacing and I've had no problems with it. They just aren't the best choice if you're looking for low cost.
rchunter
933
72
I've got a synology 1513+ but I mainly use it for streaming flac/dsd files via minimserver with my auralic aries<parasound gear. For any kind of video transcoding the synology is useless. I built a unraid haswell e3 xeon rig for all my video files bluray rips, etc.
Aikouka
30,383
912
I don't believe any of the NAS devices support transcoding in Plex because of Plex's use of a custom FFMPEG library. It's a bit confusing because there are a few sort of newer ones using Intel's Evansport CPU, which features QuickSync; however, Plex cannot use it.
poofyhairguy
14,612
318
Yeah Plex needs CPU power for transcoding, it can't use fixed function hardware. Any Core 2 Duo or better dual core with 2.6 GHz or better can do the job.
smitbret
3,382
17
Agreed, if you are going to use Plex, you are better off with a DIY unRAID system. Even if it takes a little work to learn what you are doing, you will be happier in the long run.
ControlD
5,440
44
It depends how many concurrent transcoding jobs you want and what quality they are at. Now that my wife has started to watch stuff on the Plex server I am sort of thinking it might be time to upgrade the CPU a little bit. I know my G530 can handle one 1080p job, but I think two at the same time is pushing it.
poofyhairguy
14,612
318
Good point, I should have clarified that is enough for a single stream.
JoeMcJoe
327
I got my TS-451 for about $350 then I added 16GB Ram. Not the cheapest, but I think it is really nice for the price. It runs a few VMs too.
The Plex does have the transcoding, but it might be always a few versions behind the most current release.
