You're welcome.
Another suggestion depending on what you are looking for is a notebook. Best Buy has a Toshiba notebook that has the Celeron 1037U CPU, with 64-bit Windows 8, a 500GB HDD, DVD drive and 4GB RAM for $229.99 + tax. Factoring in cost of Windows, you can't build a box for that cheap. You can just run it with the screen closed.
I already have everything else though or else this would be the best option. I ordered the ECS version of the board.
Newegg had 3 choices for the Celeron 1037U Embedded Boards
Foxconn - 79.99
ECS - 79.99
Gigabyte - 89.99
I went with the ECS version. The Gigabyte is the best option most likely, but I won't use the extra things it comes with. (Dual Nics, Full size Dimms, etc)
I went with the ECS board over the Foxconn because
A) Has a Full size PCIe x16 2.0 Slot, where as the Foxconn is 1 PCI only.
B) Better Reviews
I have a 4GB SO-DIMM DDR3 chip here, so I decided to go with the ECS board for now.
