E: So I of course did not read the thread, so feel free to ignore all that below. The way I understand it is, low carb = body burns fat stores more often for energy. Which leans you up. However, if you excercise, keep your carb count in check (not low but reasonable), and stay at a caloric deficit you will also lose weight (fat). I guess a "low" carb diet would be any significant deficit over what the FDA claims is the daily amount you should eat. If its 200 for your weight, 150 or 100. I'd say 25%-50% reduction would mean "low" for the average person. For a bodybuilder looking to cut down, and quickly at that, I'd say 50%-75% would be "low". Depends on the person and goal, I suppose.
When I switched to low carb it meant cutting out most breads. I switched to low carb wraps (normal wraps have just as many, if not more carbs, than their bread counterparts) as well as cutting out any juices, fruits, or other sources of sugar.
When I was really aiming for low carb days, under 50, my biggest source of carbs came from a greek yogurt at lunch, 20g.
Lately my carb intake has been much higher, especially with my new job and lack of motivation early in the morning to actually make food so I resort to restaurants.
Best way to start: Cut out breads as much as possible, including breading on meats. Look at the nutritional facts of everything you normally eat, start cutting out most any snack type item that has a lot of sugar, especially considerably more than it has fiber. Switch to sugar free or un-sweet drinks (coffee creamer, juices, soda, etc).
The whole grains theory, if I understand it correctly, is just that the carbs break down into glucose in your blood stream slower so you stay full longer and don't get a blood sugar spike, which in turn triggers your body to start storing fat.
Remember that during a low carb diet or life style you'll need to make sure you're eating fats. Fat free food usually means "more sugar to make it taste better" so stay away from them. You also can't do low-carb and low-fat and expect to have any energy. You need one or the other, especially after you're body starts getting rid of your fat stores, if you aren't eating either you'll just stall.
Hopefully this rant of low carb advice helps you. 🙂
