imported_Truenofan
- May 6, 2005
- 1,125
- 0
- 0
i used to fantasize about how much power a quad rotor would make, rarely a triple.
http://www.turborx7.com/20bbasics.htm
the rotary cosmo triple rotor weighs in at just over 700lbs with all accessories, meaning ac, ps, manifolds, turbos and transmission i believe.(i honestly thought it would be a little lighter, just have to wait for triple rotor 16x's, but those would be 24x's)
the racing triple rotor shortblock weighs in just over 300lbs. if you go to the bottom of the page, you'll read about what some people have done with triple rotor engines.
the triple rotor drag cars have hit 1500hp with no failures for four seasons, pretty impressive when you think of it
http://rotarynews.com/node/view/549
personally i dont plan on getting anything greater than 300hp at the wheels, i dont need more and dont want more. I'll be more than happy at 300rwhp with a 1300ish usd rebuild and port, and hell, i dont even need the port job i just want it for more flow. i enjoy going for a circuit course or autocross more than straight power, and on turns, you don't want a car thats heavier, its just not good for it no matter what excuses you make for getting a ls1. a lighter car IS and always WILL be better for cornering, go as supercar manufacturers why they replace as many parts with carbon fiber and aluminum or other light weight materials. if your on a course that has minimal straights, whats going to matter more. turning speed or horsepower?
I'm even thinking of removing the sound deadening in my car via dry ice and a hammer. it would drop the weight by at least 15lbs. I'm removing my ac, my ps, seeing if i can change my water pump to electric or getting under drive pullies for the water pump(for reduction of a possibility of cavitation if i cant get it electric instead) and alternator as well as electric fans to reduce parasitic loss even further. if(big if, more than likely not) i make my car a track car only, i will end up replacing my rear window with a light weight window and replacing both doors with fiberglass doors to reduce the weight even further as well as removing my sunroof and whatever else i can.
