JoLLyRoGer
- Aug 24, 2000
- 4,153
- 4
- 81
Originally posted by: Zombie
Well not really tight budget but this is going in a family room and screen will be positioned above the Mantle. Power screen will let the wife do her thing(interior design) without forcing me to spend 3k on power screen.
That screen is 16:9 format. I called and asked. The woman wasn't sure about the material of the screen though.
I can see why you would want that then. There is something for every application and if this is going in your family room (where I doubt you have total control over ambient light) then you might be better off with a matte white screen. High contrast does lower overall brightness (which you'll need all you can get unless you have a dedicated screening room or only plan to watch at night).
