Genius. I've got like 500 of the damn things. Might actually be a useful item in a survival kit
question is, are fan grills pure stainless steel? or zinc galbvanized? how can you tell
I'm almost 100% sure they aren't stainless steel. There is no reason for them to be. They are probably chromed mild steel or chromed aluminum.
Vrolok - With a tin can or some other sort of can you could heat a small batch of water pretty easily - perfect for an MRE or other mix-with-water meal.
I think I'll still take my mini camping/survival stove over this lil guy.![]()
What kind of fuel does it use
Yes, they are chromed steel. They're the wrong color for stainless, and yes, the coating will flake off if the wire is bent or damaged.I've seen them flake before. I'm sure it varies, but AFAIK they're just chromed steel.
In the United States the dietary guidelines for daily chromium uptake were lowered from 50-200 µg for an adult to 35 µg (adult male) and to 25 µg (adult female).
Acute oral toxicity [for chromium(III)] ranges between 1500 and 3300 µg/kg.
The acute oral toxicity for chromium(VI) ranges between 50 and 150 µg/kg.
