loaded coronas are SO good
Jun 26, 2007
11,925
beside ever clear, what other cheap rum or volka that can be lit on fire? I want to do a flamming raisin.
1. raisin
2. rum (i used the cheap $10 rum from bevmo), it does not light on fire
3. spring some brown sugar on the raisin.
4. light it on fire.
Anything above 40% will be flammable at room temperature.
Don't drink volka though, that shit is toxic.
NetWareHead
THAT guy
Aug 10, 2002
5,847
154
100 wont light...you need 151 proof or higher. Most good liquor stores should stock 151 proof.
edit: before someone corrects me, yes 80 and 100 proof will burn but I've only successfully ignited them when heated. 151 will burn at room temp
11,925
You know what is better than that?
Bourbon, the French sorted whiskey isn't anything but bad cognac.
It's Laphroaig, 10 years is the best one, it starts to loose character after that, it's either that or nothing at all.
If you're not having that, you can go ahead and order a fruity drink.
Jun 26, 2007
11,925
Have you ever actually tried lighting 100 proof? It doesn't work unless you heat it on the stove first, and even then it doesn't always light.
You can light 80 proof just fine at room temperature, all you have to do is keep the lighter on there until there is enough vapor to ignite the flame, it's usually just a blue flame at that point but it is still there and it can fool you and burn your lips.
Why the fuck you'd want to burn off the alcohol from a drink i don't know though, well perhaps with 151 because that much alcohol is too much.
At that point, just get some strong wine and take it rectally, if you are not going to enjoy what you are drinking, this is the easiest and fastest way to get all macked.
lxskllr
60,530
10,900
Bacardi 151 is fun for the experience. The burn is an interesting sensation.
Perknose
Forum Director
10,728
147
This one's so loaded it's even got whitewall tires! :D
lxskllr
60,530
10,900
Whitewall tires are probably the thing I miss least on older cars. The concept is stupid, and the early whitewalls where the whole side is white looks ridiculous.
weflyhigh
971
the only reason we had corona was to mix the bacardi with
it tastes so good and agree corona is nothing special. i usually drink Natural Ice
