Originally posted by: alembic5
You need a lift for 33's? I put 31's on my Ranger without a lift and had no rubbing. And let's face it, a 2-3" lift wouldn't make much difference at all, so long as you got a quality kit and a quality install. The good ones shouldn't be overly detrimental to on-road performance, but the cheap ones can really mess it up. I've had a couple of friends with high quality 2" kits that gave them just enough to fit on some bigger tires, and they rode almost like stock. Road noise will be almost entirely dictated by your tire tread design, so do your research! I had BF Goodrich All-Terrain T/A KO's, and I loved them. They were considerably better than the stock Goodyears in on-road performance, particularly with wet roads. The mud terrains that my friend had on his rig were considerably louder on the freeway, so beware of that if noise is a concern. Do it right, and don't drive like a jackass. You'll be fine, and so will others. Just don't be one of those toolboxes that get super swamper boggers on their commuter rigs because they look cool! 🙂
