Life's greatest problem solved by MIT
lxskllr
60,045
10,533
really? FDA is pretty good and strigent as far as I know. Some products turn out less safe than thought, but you gotta consider the sheer volume of products they approve
The FDA, like the rest of government has been bought by corporations. They give lip service to safety, but their primary job is keeping their masters happy.
sixone
25,030
61
Much like your Energy Star ratings. Absolutely worthless.
Feb 6, 2007
16,432
Any fix for the flatulence sound the cap orifice makes when it's nearly empty?
D:
That's the best part of the ketchup experience. When I get a new bottle of ketchup, the first thing I do is dump 90% of that shit directly into the trash. What do I want with a condiment that doesn't imitate bodily functions when you use it? Nothing, that's what!
Nov 7, 2000
16,403
allowing safe products to get to market is not their useful function. keeping harmful products OFF the market would be. IMO harmful products wont survive in the market regardless so its basically just wasted time and money. you could argue that they would save lives by keeping harmful products away from the public, but i dont know if there is evidence to support that. not to mention, if that is a rare occurrence, its still probably not worth the expensive bureaucracy.
dank69
37,358
32,990
Yeah once a few hundred people drop dead we should be able to narrow down the cause. Let God sort it out. :rolleyes:
Miramonti
28,653
100
This will be costly as unknowing consumers flood their plate (more than normal) with ketchup. Ketchup eaters are generally slow learners too. :p
Rubycon
Madame President
Aug 10, 2005
17,768
485
Changing the orifice (which may explain the noises it makes when air mixes in given it's similar to an anus) can prevent this. Next is to eliminate the deluge of diluted catsup (this happens with mustard too!) that squirts out first. Shaking the bottle first helps reduce it but most just grab and squeeze before realizing they made that mistake and have a soggy wizzed on bun full of catsup or mustard juice! D:
Feb 6, 2007
16,432
Everything about this paragraph just ruined ketchup for me.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Why would you want to fix that?
:colbert:
edit: in fact can we add this to more products?
Some folks find it highly disturbing to hear "sounds of gastronomical disturbance" [sic] at the dinner table.
OTOH I've recorded quite a bit of this phenomenon from various bottles - some shampoo bottles work even better due to the elevated surface tension of the medium. Doing a pitch transpose downward and playing it through a capable system can make some frightening noises only eclipsed by human imagination.
EDIT: High speed (10,000+ fps) recording of the action of these orifices when "farting" would be interesting. D:
13,804
I did not realize they still made glass bottles. That's kind of cool. Wonder if this stuff works as good on plastic.
In fact I wonder how good it works on ABS. Could coat the inside of the main stack so poop can flow better to the city and not cause a clog. Especially those caulk like poops that come out and just want to stick to everything.
Mar 10, 2005
14,647
i always send the first 1/2 squeeze down the sink. hugely wasteful, but i can't accept a soggy whizzed-upon burger and bun.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Better play it safe and flush the line than have a soggy bun. I suppose if you do it enough you can get good enough to predict where it's going to come and make sure the juice lands on the wiener only keeping the bun dry. :D
lxskllr
60,045
10,533
Shake it first, sheesh... On the final shake, you use a sharp stop on the downward motion, so it all goes to the end. I don't use ketchup, and I've decided I despise squeeze bottles, so I only get mustard in a jar. Whenever things get made superficially easier by manufacturers, there's always unintended consequences that make them harder over the long term, or wasteful.
DAPUNISHER
32,039
32,527
Giggity!
Nov 3, 2004
10,491
22
Harmful products won't survive the market? Consumers are pretty ignorant twits that will often just buy whatever the label claims it does and whatever is cheapest. The only way your argument could make any sense is some libertarian argument where a private company informs consumers and becomes a de facto regulator, but it still won't have the regulatory power/access because it will be more profitable for offending companies to mislead those regulators.
AMCRambler
7,715
31
http://mobile.nytimes.com/2015/03/2...stick-coating-the-wait-and-waste-is-over.html
They're still talking about this breakthrough 3 years later. There must be some type of catch to it. Like the lubricant is seriously cost prohibitive to produce or ends up breaking down/mixing with the contents over time losing its effectiveness. I haven't seen it touted on any of the food containers we have. Disappointing because this seems like a genuinely good idea.
