Let's see your keyboards
stargazr
4,268
3,879
repoman0
5,191
4,574
I've been using a WASD Code 104-key with MX Clear switches for the past couple years. Recently replaced it with a WASD V2 87-key again with Clears (basically the same thing minus backlighting and minus the number pad). I bought the barebones one with no keycaps and supplied my own PBT plastic caps, which surprisingly makes it feel significantly nicer and more solid ... less "clacky" despite the switches being identical. They also supposedly will not get shiny like ABS plastic caps do. Also using a separate number pad made by Leopold because I wasn't sure I wanted to give it up completely.
I've been toying with buying a Leopold 87-key with MX brown switches and stealing the keycaps from it so it matches my number pad :rolleyes:
WASD Code (will be moving to my desk at work):
WASD V2:
Numpad:
Reactions: Crono
35,567
^ way mo better keyboard than the M type
The M type just happened to be the last decent keyboard before twenty years of keyboard suckage.
clamum
26,256
406
I've got 3 IBM Model Ms and this one:
2017-04-03 21.58.26
Wow man, I think yours takes the cake. That's really nice looking. A lot of people don't like the "split" keyboards but I like them (probably helps I touch type "correctly" like I was taught, heh).
Here's mine, it's kinda old and worn. Should look at replacing it some time. Hard to find a good quality wired keyboard now days though, everything is wireless.
Man once I went wireless for my mouse and keyboard (mouse a couple years ago I think, keyboard not quite a year), I'll never go back. I love wireless, no frickin cables to annoy and get in the way. Also I've not noticed any drawbacks for games or anything, other than the occasional battery replacement (I just pop in another of the bunch of rechargeables I have). The day when power/data can be all transmitted over the air and there's no longer a tangle of cables behind your PC/home theater/etc will be the day I cry in absolute happiness and track down the inventor of said tech so I can fellate him until he passes out.
BudAshes
14,012
3,401
I prefer the semi-mechanical style. Not quite as loud, but still fairly satisfying to type on.
Reactions: Crono
MrSquished
26,790
24,940
Add me to the Corsair K70 RGB list but with the MX Speed switches. And have no problems typing with them either. They are amazing for gaming
Reactions: Crono
snoopy7548
8,304
5,385
That thing does look sweet. It'll probably be my next keyboard. Do you go crazy with custom LED sequences for each game?
MrSquished
26,790
24,940
I don't. I keep a primarily static 4-color custom lighting scheme for everything with a setting that every key I press while in Windows changes color briefly. Anything with too much motion just gets annoying to me.
I set a matching color scheme on my Steelseries Rival 600 mouse and Prism mouse pad. I'm a 42 year old kid that loves blue lighting, but doesn't need the bling.
Platypus
31,046
321
Thanks, I've found it to really help with shoulder/wrist pain since I basically live on my keyboard for my job. That photo doesn't really show the layout I usually use but it's easier to get into one frame. I separate the halves to be even with where my shoulders are. It took a long time to put that stupid thing together because of the hilarious and wild world of buying custom keycaps, but it's sped up my workflow a lot. The firmware is just C, so I programmed a lot of custom multi-button macros to all the various unmarked buttons and that shit is amazing for repetitive tasks.
This thing made me realize that I had two very annoying bad typing habits and it punishes you hard for that. It didn't take long to correct those issues and now I find I'm a lot better on other keyboards as well. I've used ergo keyboards for the last 15 years or so and I really like the ergodox design.
KMFJD
33,992
54,761
I've got a mechanical keyboard(G910) and just a plain old hp keyboard at work
Stopsignhank
2,754
2,253
I like using the keyboard on my laptop. I had to do it on a business trip and realized that I like it better than a regular keyboard. I think because I am lazy and I don't have to push the keys down as far.
purbeast0
53,762
6,644
ePeen negative one thousand for using a Mac. Your ePeen is now officially an innie.
I've owned HP laptops, Dell laptops, and now a MacBook Pro (2014 model I got in 2015) and there is no comparison. The MacBook Pro is leaps and bounds better in every way possible than any other laptop I've ever owned.
Oh and I use it for iOS development, so there is that too...
DigDog
14,828
3,099
i like TKLs.
1. VicTsing TKL with Outemu blue and dampeners (circa $35 shipped)
2. Topre Realforce TKL 55g (circa $300 shipped)
3. CODE TKL with cherry mx clear + PBT caps (circa $200 shipped, plus tax)
Nongshim Udon noodles
Reactions: Crono
