Originally posted by: geckojohn
So, can anyone answer my question: how to burn to a vcd Cd so that i can play on a standard dvd player? please respond...
Use what you have to get started, then try more programs to see if quality is worth it.
I started with a CDRW, so I wouldn't waste CD's.
Basically, here is simplified method.
1. Record program to your hard drive. AVI will be best quality but huge. Mpeg is fine for testing.
2. After saving your program to hard drive, Open Ulead, click "Capture" then on upper right screen click on
File Folder and browse to your saved program.
3. You are limited to the CD size, so to test quality and size output, start small. On the bottom of preview window,
slide the Mark-In and Mark-Out pointers until only about 20 minutes of your program is selected (green bar).
4. Click "Finish" , Create VCD, use Preview Portion only selection (or something like that), then follow on screen instructions.
5. It will correctly setup the CD to play in a DVD player.
Play around with quality and settings using your CDRW until you find what works best for you.
