Discussion Leading Edge Foundry Node advances (TSMC, Samsung Foundry, Intel) - [2020 - 2025]
DisEnchantment
1,779
6,798
TSMC's N7 EUV is now in its second year of production and N5 is contributing to revenue for TSMC this quarter. N3 is scheduled for 2022 and I believe they have a good chance to reach that target.
N7 performance is more or less understood.
This year and next year TSMC is mainly increasing capacity to meet demands.
For Samsung the nodes are basically the same from 7LPP to 4 LPE, they just add incremental scaling boosters while the bulk of the tech is the same.
Samsung is already shipping 7LPP and will ship 6LPP in H2. Hopefully they fix any issues if at all.
They have two more intermediate nodes in between before going to 3GAE, most likely 5LPE will ship next year but for 4LPE it will probably be back to back with 3GAA since 3GAA is a parallel development with 7LPP enhancements.
Samsung's 3GAA will go for HVM in 2022 most likely, similar timeframe to TSMC's N3.
There are major differences in how the transistor will be fabricated due to the GAA but density for sure Samsung will be behind N3.
But there might be advantages for Samsung with regards to power and performance, so it may be better suited for some applications.
But for now we don't know how much of this is true and we can only rely on the marketing material.
This year there should be a lot more available wafers due to lack of demand from Smartphone vendors and increased capacity from TSMC and Samsung.
Lots of SoCs which dont need to be top end will be fabbed with N7 or 7LPP/6LPP instead of N5, so there will be lots of wafers around.
Most of the current 7nm designs are far from the advertized density from TSMC and Samsung. There is still potential for density increase compared to currently shipping products.
N5 is going to be the leading foundry node for the next couple of years.
For a lot of fabless companies out there, the processes and capacity available are quite good.
FEEL FREE TO CREATE A NEW THREAD FOR 2025+ OUTLOOK, I WILL LINK IT HERE
moinmoin
5,248
8,463
Does Intel already have fabs in Israel? I guess Tower could enable local experimental silicon design research for the already existing local Intel design teams. Other than that it sounds like a potential good fit with (also local) Mobileye.
NostaSeronx
3,815
1,294
That's...a controversial term.
CMT was coined by Charles R. Moore, not by Marketing.
CMT as an idea predates Andy Glew and Charles R Moore at AMD; https://patents.google.com/patent/US6119223A
David B. Witt had lead roles for Am29k, K5, and K7.
James B. Keller is Jim Keller which at the time had a lead role for K8.
Rather than being derived from Charles R. Moore and Mike Butler work, it is derived and changed from the original CMT development.
There is also separate starting points:
AMD's improved am29k/k5 dual-core initial architecture was built in mind with sharing a thread across both cores, as it was penned before AMD's early SMT in K9.
AMD's Bulldozer dual-core initial architecture was built in mind with not-sharing a thread across both cores.
Early CMT = Closely connected cores. Core<->Core at PRF via strong rename unit(Multi-core Mapper).
Bulldozer CMT = Distantly connected cores. Core<->Core at L2 cache.
The whole GF FDX stuff is dealing with profit margins and time spent at expenditure(loss) and getting to profit(gain) quick.
+Highest performing digital transistor available at GlobalFoundries at lowest cost of development and production, given at 22FDX w/ GF/SOITEC/Leti Strained SOI in 2H2022 to 2H2023.
oak8292
211
228
witeken posts as Arne Verheyde on Seeking Alpha and his last post from Feb 10 says that he is still long on Intel but he is neutral on Intel and looking for answers in tomorrows Intel Investor days.
I will speculate that the five 5000 NA EUV research machines will go to Intel, TSMC, Samsung, SKHynix and Micron. Intel has placed the first order for a 5200 NA EUV production machine on January 19, 2022.
The world is heading to tiles and chiplets. The cost of a 400 mm N2 or 18A die is going to be high with 5200 EUV machines going for 300+ million a piece. Intel is already using some 'tiles' from TSMC and they will also need some RF and silicon photonic tiles on larger geometries to complete SOC, SIP or MCM or whatever multi die nomenclature you want to use. The traditional 'leading edge' has meant the smallest geometry, however, TSMC, Tower, GF and everybody else getting left behind on size has been trying to find ways to 'lead' on larger geometries and there are profits to be made.
19,219
The long-term progression of Moore’s Law requires overcoming the exponential growth in the power consumption requirements of current CMOS-based computing7. To continue, to scale ultra-low power solutions that use quantum effects in materials (called quantum materials) at ambient room temperatures will be required. In 2021 at IEDM, we reported a huge milestone in beyond-CMOS device research: the first functional demonstration of a magneto-electric spin orbit logic device with its read and write components functional at room temperature. Both the spin orbit output module and a magnetoelectric input module are integrated together into the device, and magnetization state reversals are achieved via applied input voltage. With its ability to realize the higher functionality majority gate (versus NAND and NOR ones) three MESO devices forming ultra-low power majority gates can implement a 1-bit adder, which would otherwise require 28 CMOS transistors
MESO sounds groovy.
Exist50
2,452
3,106
Looks like there’s some new information here. Most notably numbers for 20A PnP and the 18A timeline.
Ushering in the Angstrom Era with RibbonFET and PowerVia, Intel 20A will deliver up to a 15% performance per watt improvement and will be manufacturing-ready in the first half of 2024. Intel 18A delivers an additional 10% improvement and will be manufacturing-ready in the second half of 2024.
Also, an interesting bit of wording.
Intel remains on track to reclaim transistor performance per watt leadership by 2025.
Might imply that Intel doesn’t think they’ll be ahead in density.
eek2121
3,491
5,190
No company gets close to peak (or even average) density for their performance parts. Look at Zen 3, for example.
Exist50
2,452
3,106
Irrelevant. If Intel expected to lead in density in any plausible way, they’d probably mention it.
oak8292
211
228
Everything seems to be in track at Intel:
It looks like 18A has been moved up. The presentation last year had 18A as a 2025 product;
"Intel 18A is already in development for early 2025 with refinements to RibbonFET that will deliver another major jump in transistor performance. Intel is also working to define, build and deploy next-generation High NA EUV, and expects to receive the first production tool in the industry."
It also appears that 18A may be an optimization without a shrink on 20A. The first NA EUV machines won't be available until 2025 per their announcement earlier this year.
Intel appears to have gone to half node advances to mimic what TSMC was doing. It makes sense from a capital perspective since they can't afford to move full nodes on an annual basis. In fact it looks like 20A is a node very similar to TSMC's N10 with a single client product, it will be a 'short lived node' as TSMC would say.
dullard
26,196
4,869
I just came here to say that.
For 20A: "expected to ramp in 2024" became "manufacturing-ready in the first half of 2024"
For 18A: "in development for early 2025" became "manufacturing-ready in the second half of 2024"
19,219
Things should get very interesting once Intel uses their "process leadership" (that's what they pride themselves on) to make their GPU's scream at 3 GHz and beyond. Less compute units would replace many and then they get to make more GPU dies per wafer.
maddie
5,205
5,618
"expects to receive the first production tool in the industry."
Does this mean what an earlier member suggested, namely that single machines would go out to the main fabs as evaluation machines giving them the chance to get familiar with using them.
If yes, then this is just another PR job.
Having a smaller market cap than AMD must hurt so badly.
dullard
26,196
4,869
Wow, that just reeks of desperation from you. You turn a comment about receiving a tool into a who has the biggest ___ contest? If you are going to be that petty, so will I. AMD market cap as of the time of your post: $191.52B, INTC: $196.34B. If you are going to be that petty, at least be correct.
oak8292
211
228
GPU's are typically wide and slow to keep them power efficient.
My understanding is that the ASML 5000 machines being shipped are development machines to 'get familiar'. The ASML 5200 that Intel ordered is supposed to be the first production machine. I don't know where Intel is on process development with the 5000 machine or how many layers will be required for their first NA EUV process.
With the current EUV machines it is roughly one machine per layer per 40 Kwspm. N5 has about 15 layers and to ramp to their target of greater than 100 K wspm they will need around 50 EUV machines. Really rough numbers from a non-expert.
A single machine is probably PR but it is really early for 2025. ASML needs solid orders to get ASML's mirror manufacturer Zeiss to increase production capacity for NA EUV. Lead times are years and not months.
Roland00Address
2,196
260
Just started, Intel is doing a 3 hour event. Targeted as an Investor Meeting where they are going to be talking things like IDM and other stuff. Here is Dr. Ian Cutress live tweeting it.
Intel 18A pictured. ( it is SRAM it will be years before CPUs or SOCs are in computers )
IntelUser2000
8,686
3,787
So Meteorlake compute tile hasn't been taped out yet? Takes a year so if they want to make it H1 like some people here are expecting they only have few short months to do it assuming it takes exactly 12 months to a product.
This is why I don't like the new "taped-in" terminology. Makes it sound like they are doing more than they are actually doing rather than in the old days where they only said things when tape outs occurred.
Also what is the server chip on the Intel 3 process?
2022 H2 - Sapphire Rapids Intel 7
2023 H2 - Emerald Rapids Intel 7
2024 H2 - Granite Rapids Intel 4? 3?
So Granite Rapids is Intel 3 rather than Intel 4 now? Or they don't need Emerald Rapids anymore? At least good to know that there's something big on Intel 3, otherwise that process would have been dead as a dodo bird.
Update: Ok wow so it looks like Granite Rapids is moving to Intel 3 from Intel 4. Good for them.
