I was told long ago that if you have a room that is dark so no glare, get a Plasma, if you have glare issues get a LCD. That being said, I have a 12sq foot skylight in the center of my living room so I got a LCD.
Guys, would you say a plasma screen is more reflective, about the same, or less reflective than the old standard CRT TV screens?
No. Plasma doesn't beat LEDs in power consumption.
Yes, plasmas have a cheaper purchase price. But they also cost 2, sometimes 3 times as much per month to operate. The suck a helluva lot of juice AND give off a lot of heat (which may be a factor if you live in a warm climate and run your air conditioning a lot).
When you factor in operating costs with purchase price, the price discrepancy is less. And then factor in increasing costs of electricity in the coming years (we're f*cked if President Obama's "cap and trade" plan becomes a reality).
If you're going to keep this tv 15 years like your tube tv, you might want to consider that.
[sarcasm]You're right: plasmas consume so much more energy than LCDs, that within a couple years, you lose any cost benefit from them.[/sarcasm]
According to CNET, the Panasonic TC-P50X1 costs $55.28 per year to operate (source), and the Philips 42PFL6704D (closest size to 40" I could find with power consumption) costs $39.65 to operate (source).
So, over the course of 5 years, your parents will spend $78 more to operate a TV that's far superior in quality and size. To get an LCD in the same size and quality as that Panasonic plasma would likely cost HUNDREDS of dollars more and certainly not $78 more.
Edit: I just fed the number of Watts consumed into my utility-cost calculator, and to get CNET's numbers for those two TVs, I'd have to have my TV on for more than 9 hours every single day. So, if your parents watch half that much TV, then the difference in electricity costs over the course of 5 years would be $39 instead of $78.
Edit2: Another way to look at it is that even if they had the TV on 24/7 for 5 years straight, they'd only be spending $200 more on electricity to have the 50" Panasonic plasma compared to that 42" Phillips LCD. You can guess which one I would choose :biggrin:
I just gotta say that if you :
a) even notice the price difference between energy consumption
and
b) it's a big deal to you
then you
a) need to cut back on your TV useage
and
b) probably shouldn't be spending that much money on a TV.
You keep posting this FUD, and I'll just post the same reply I did last time:
Question 1: Do plasmas consume more energy than LEDs?
Answer 1: Yes
Question 2: Will buying a $3,000 LED instead of a $1,500 plasma ever save $1,500 worth of energy?
Answer 2: No
Even if you buy a display and have it on 24/7 for the next 15 years, a plasma is still only going to consume about $600 more electricity than a comparable LED TV. Even without factoring in the time value of money, you're still ahead by buying a plasma than an LED. If you do factor in the time value of money (i.e. a dollar today is worth more than a dollar 15 years from now), then you're WAY ahead by buying a plasma than an LED.
This comparison becomes even more in favor of a plasma when you look at how much your TV is on every day. It's likely less than 8 hours, which means 15 years of being on 8 hours every day is going to cost you a whopping $200. Show me a 50" LED TV that rivals a 50" plasma TV for only $200 more, and I'll stop countering your energy-consumption FUD.
Sorry I'm not a Plasma fanboy like you.
LCD's put out a buttload of heat too. The heat coming off the front panel of my 46" LCD is enough to shift the thermostat near it a couple degrees. Even walking by it you can feel the heat radiating from it.
FUD away.
the Samsung plasmas aren't free of issues either. I'm sure you have read the threads on AVS.
Unless you shell out the big bucks quickly disappearing Pioneer KUROs you cant really find a "perfect" display anymore
Im picking up my Panasonic P50G20 tomorrow
http://www2.panasonic.com/consumer-...TVs/model.TC-P50G20_11002_7000000000000005702
Runco plasmas are still up for grabs. 🙂
3500+ if you can find them. which isnt a bad price, just more then what i was gonna spend
